Here are the SPECS for the Pioneer 700-4
64,272
Here is a list of specs that Honda has released on the Pioneer 700-4 side by side.
Specifications:
Colors - Red, Olive or Honda Phantom Camo™
Engine Type - 675cc liquid-cooled OHV single-cylinder four-stroke
Bore And Stroke - 102mm x 82.6mm
Compression Ratio - 9.2:1
Induction - Electronic fuel injection (PGM-FI), 40mm throttle body
Ignition - Full-transistorized type with electronic advance
Cargo Capacity - 1,000 lbs.
Towing Capacity - 1500 lbs.
Transmission - Automotive-style with hydraulic torque converter; three forward gears and Reverse; three drive modes: 2WD, 4WD, and 4WD with front differential lock
Ground Clearance - 10.5 Inches
Front Suspension - Independent double-wishbone; 7.9 Inches
Rear Suspension - Independent double-wishbone; 9.1 Inches
