P1000 Is the 1000 Really that Bad?
mlhannah1
22
61
Chillicothe, Ohio
Well guess what, another recall for the pioneer. The Honda shop has our machines more than we do. I guess I can get my shifting cables worked on at the same time. Just wish Honda would have tested this machine, like they used to test there old fourwheels.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
How much time has it really been in the shop? When I got the updates done on my 16' (clutch included) it was in and out the same day. When I did my first service on my 18' which includes valve adjustment, i dropped it off at 11am and it was done by 3pm the same day.
Anyone leaving their machine for more than a day is getting jerked around. Tell the dealer to get their s*** together or go somewhere else.
They had mine for a day and did every update available. Only took them a few hours.
E
elkguide
3,377
7,964
Vermont
When I had mine in for the clutch update and all, since I had a 2 hour drive each way, I scheduled a first thing in the morning appointment (9:00) and was out the door at 12:15. Then since the tech messed up and pinched an O-ring (cost him his job) and it needed to go back, the dealer asked if I could wait till the weekend and he would come and get it and bring it back the following weekend.
So I guess that I could complain that they had my rig for an entire week BUT I'm happy that I didn't have to lose a day of work and glad that I have a great dealer.
mlhannah1
22
61
Chillicothe, Ohio
Well when my machine had 83+ miles on it the transmission went out. Honda had it for 3 weeks (also requested my first service). Then went back to Honda at 133 miles to have the clutch, heat kit with my friend (Asked them to redo my first service since it was in the shop the first time). They had them for the entire day. The first Honda shop did not put the o-ring on the transmission filter right. Half in half out, said it was leaking oil all over the bottom of my motor. Also said I was missing a metal dowel rod out of my clutch cover. This shop said it fixed everything.Pulling my machine off the trailer, I see the gear indicator does nor change. No 4 wheel, or 2 wheel, or truff mode. Put this thing in my garage. Now with the new recall, about the intake maybe I can take it back in and get everything fixed! (yeah right).
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Sorry to hear you've had a run of bad luck. Were those Honda dealers or multi line dealers. Maybe @Neohio could help you find a better place to go. I've never had a machine in the shop for more than half a day. That's including updates and the 1st service.
Reactions: BWAF
Neohio
Neohio
Beast of the East
13,536
67,236
Painesville Ohio
I am not much help on dealers either. Mine wants my machine for upwards of 3 weeks to do all the campaigns. I am not willing to be without it for that long.
I have heard good things about Just For Fun in Middlefield. I have good dealings with Off-Road Express in Erie PA as well, but have not used their service department to vouch for them.
If you weren't 4 hours from me, I would offer my garage to get it sorted quickly. The adjustments are easy, the dowel rod issue etc, I'm sure we could order parts and figure it out. Taking engines apart does not bother me at all.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
That's crazy! Theres no reason for a dealer to have a machine for 3 weeks. Absolutely f***ing nuts!
Neohio
Neohio
Beast of the East
13,536
67,236
Painesville Ohio
I might pull a Kilo and install the campaign myself.
I don't care about the exhaust or heat shield. I would like the clutches done eventually, but not bad enough to let them have it 3 weeks.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
The dealer where I purchased the machine in Spokane, Wa, did the first service, the recal, and installed my warn winch. I showed up at about 11:30 in the morning, and loaded up and headed home at about 5:45 that same day.
As far as problems go.. EVERY machine has their own issues. Many of them have worse heat than the Pioneer. No machine is perfect.
With the help of the cool folks on this forum, it's easy to determine what you need to do to rectify the issues. I can't say enough about how much help y'all have been!
I've only had mine for just short of 3 months/180 miles, but I love this thing!
Neohio
Neohio
Beast of the East
13,536
67,236
Painesville Ohio
Reach out to @HondaTech He has recently relocated to a new Honda dealer. I think he is in the Cinci area, might be worth the drive to have a knowledgeable tech work on your equipment.
Reactions: BWAF
Kilo427
Kilo427
1,543
6,440
I certainly can help if you do :)
HondaTech
Right now we are doing all campaign/recalls by appointment or drop off. If you schedule it for a certain day, itll be done that day. But we were 1&1/2 to 2 weeks out on appointments this summer. If you were to doo everything in 1 shot (heat, clutch, muffler and throttle body) It shouldnt take a good guy any longer than 2 hours, hell it only pays 3 hours for all 4.
At the moment I dont believe Honda is being picky about parts, everything is open order and available. We do have to take a picture of the muffler recall after it's done, apparently some of them weren't getting the original shield installed back with the new parts.
Reactions: BWAF
HondaTech
Bring it on, we've slowed down a wee bit, we'll take all the work we can.
Just give Honda of Fairfield a shout!!!
Buford
Buford
362
586
U.S.A.
Only 2 hours to do all 4 ? I'd like to meet that tech
Reactions: BWAF and DG Rider
HondaTech
I'd like to know as well. I thought somebody said just the clutch update was like 3 hrs?
I can do a 5 seat clutch update in 45 minutes without taking the skid plate off. If I remove the skid plate (which I do only with stock plates, avoid mess) then make it a hour.
3 seat updates with skid plate removal in 45 minutes. Ive timed myself on several clutch updates. As long as you dont hit any road blocks (dirty engine, stripped allen heads in the floorboard, etc) then the flat time of 1.6 is cake to kill.
Anyone who takes 3 hours to do just the update (not taking installing clutches, just the cover and related parts) is taking way to damm long.
HondaTech
Your already taking to him. :)
While I've never timed myself or pushed myself to do all 4 as quick as possible. I'm sure that I could do all of them in under the flat time of 3 hours. If I was trying to impress 2 hours should be no problem.
3 of them overlap (clutch, TB, and seat heat) they all require removing parts that aid in completeing the other 2. So if you stripped everything first then everything is laid out in front of you and simple to get to.
42,198
OK...i thought Honda paid 3 hrs to do it. Must have been thinking about something else.
Reactions: BWAF
