I put a deposit on it back on Aug 13th, FINALLY is in, and available to pick up tomorrow!
Cant wait to have it to haul my wood in with .
Phil
Phil
Ill post one once I get it in hand!Sweet! Don't forget...
PICS OR IT DIDNT HAPPEN!![]()
10-4!Ill post one once I get it in hand!
Congrats!Ok heres the proof!
So far its been great, was a bit freaked out when we first drove it and tried to go over 15 and the engine kept cutting out, then read in the manual its a safety FEATURE requiring the seat belts be on....
There are countless threads and YouTube videos on adding a second battery, so I'm sure you can get all the proper part numbers and such from them. I have a 1000 that I just added the dual battery setup to and it was pretty easy, but I'm not sure how much work there is for the 700. The concept is the same, but clearly where and how things fit will change.Have a roof and windshield on order and figuring out what I need for a second battery and winch set up now.
Hi thanks, yes I've been reading up on them. Thinking I will do the battery isolator kit this sites store sells and mount a battery under the drivers seat. This UTV is mainly for working so wont be a lot of accessories to start but I will put in a fuse panel up front.Congrats!
Your dealership and/or salesman should have covered a variety of things with you, including that. That's just basic stuff.
Winches: Over the years riding ATVs, I've bought $$$$ winches and $ winches, but usually in the 3500# range. On my new Pioneer 1000, I added the Badland ZXR5000 from Harbor Freight, then swapped out the steel cable for a synthetic one. Lots of good reviews on that unit, and I spent $197 (plus ~$60 for the KFI winch mount) on it versus $500-600 for the big name brands. Time will tell if it was a wise decision.
Your I presume your wife takes wood hauling seriously HAOk heres the proof! So far its been great, was a bit freaked out when we first drove it and tried to go over 15 and the engine kept cutting out, then read in the manual its a safety FEATURE requiring the seat belts be on.... We use it for hauling wood and rarely go fast so no biggy.
~ Phil
View attachment 304968 View attachment 304969
Tnx Scoop!The TrueAM isolator is definitely the way to go. Get the kit with the dual voltmeter so you always know the condition and charging state of BOTH batteries.
Finally, while it won't directly correlate to the 700, here's a great YouTube video put together by HondaSXS member @RobSparre about the Honda Pioneer 1000 Dual Battery Install. That's definitely worth watching.
Yes she does, she likes to be warm, Id cut less wood and keep house cooler, so she can set temp to 76 and I wont complain cause she helped!Your I presume your wife takes wood hauling seriously HA
Thanks I will watch it!Tnx Scoop!
Phil - here is a link to the dual battery video that shows the isolator hook up and other details.
