P700 OEM switch plate harness kit
hnt4der
6
20
California
Hello all. New member here. My wife purchased a 2021 700-4 for me (great woman). I bought the OEM switch panel kit for the ease of accessory install. Does anyone know if I can purchase the wire plug connectors that will plug into the circuit board without purchasing the OEM accessory kits to get that plug?
NewHere2
NewHere2
Village Idiot In Training
36,135
306,722
High Plains of SD
Not sure what the 2021 uses. When I did my 2018, I purchased these pins and connectors.
46883FD5 2CFA 4F71 9085 CB26FCB2A701
Hope someone has newer information.
I should add, these are the pins and connectors that attach to the circuit board in the new fuse box.
It’s not a plug and play project. The pins have to be installed in the proper place / slot in the connectors.
Reactions: hnt4der
hnt4der
6
20
California
Thank you! That’s what I was looking for. Out of stock at Mouser Electronics but found them from another electronics retailer, even on Amazon for higher price though. They are made by Molex with the same part numbers minus the first three digits.
lawoftangent
lawoftangent
23
52
Maine
I ended up purchasing a specific kit on eBay for my switch panel. for all the switches and Molex connectors, I think it came out to $60. Maybe not the cheapest option but it saved a lot of time digging and I could be certain that they would work. Switches seem like they are good quality and have had no issues so far.
I bought a crimping tool specifically made for Molex connectors (cheap on Amazon), or you probably can make do with a normal set of crimpers.
Reactions: hnt4der and Scoop
Scoop
Scoop
4,236
15,869
  3. Talon R LV
Sometimes, paying a little more to save a lot of work or headache is well worth it. Not always, but sometimes ... :)
Reactions: lawoftangent
F
FinsFursFeathers
North Dakota
I realize this is an old post but just wanted to share this info on this topic.
I just ordered what you are talking about from stratosmicro off ebay. They a a veteran owned company.
Ordered Jan. 28 received on Feb. 1.
Part #'s 132284116810 and 132292315391.
Perfect fit an came with a toggle switch. $40.00 for both
Reactions: Scoop
