P1000 Pioneer 1000 3/5 Usefull Service Facts
64,587
I thought I would put together a list of use full service facts for the Pioneer 1000. This will come in handy a lot when wanting to know what kind or how much of something.
Engine Oil
Oil Filter Part # - 15412-HP7-A01 Buy one here --> http://amzn.to/1Qxj6tb
DCT Oil Filter part # 15412-MGS-D21 Buy one here --> http://amzn.to/1Qxj9oV
Honda recommends a API classification of SG or higher, do not use oils labeled as energy conserving or resource conserving.
- Viscosity (weight) SAE 10W-30. Other approved colder weather areas can use 5W-30, or 0W-30
- JASO T 903 standard - MA
- Suggested oil - Pro Honda GN4 4-stroke oil or Honda 4-stroke oils or and equivalent 4-stroke motorcycle oil.
---- 5.5 liters (5.8 US qt) after draining.
---- 5.7 liters (6.0 US qt) after draining and engine oil filter change.
---- 5.8 liters (6.1 US qt) after draining, engine oil filter change and DCT oil filter change.
---- 7.2 liters (7.6 US qt) after disassemble.
Sub-Transmission
- Viscosity (weigt) SAE 10W-30. Other approved colder weather areas can use 5W-30, or 0W-30
---- 1.2 liters (1.3 US qt) after draining.
---- 1.4 liters (1.5 US qt) after disassembly.
Differential Oil:
Use Honda shaft drive oil or equivalent hypoid gear oil SAE 80.
- Front
---- 11.5 US oz at draining
---- 16.9 US oz at disassemble
- Rear
---- 15.9 US oz at draining
---- 18.6 US oz at disassemble
Fuel
Honda states that only unleaded fuels can be used in the Pioneer.
- Fuel tank capacity - 7.9 US gal (30L)
Coolant
Honda recommends using only Pro Honda HP coolant. However a equivalent high-quality ethylene glycol antifreeze containing corrosion protection inhibitors specifically recommended for aluminum engines can be used.
- Solution 50/50, 1:1 mixture with distilled water.
- Capacity:
---- 3.2 liters (3.4 US qt) at drain/replacement.
---- 3.5 liters (3.7 US qt after disassembly.
- Fill reserve tank to between Min and Max level.
Spark Plug
- Standard spark plug - SILMAR7A93
- Gap - 0.031 - 0.035 in (0.8 -0.9 mm)
Brake Fluid
- Honda DOT 4 brake fluid or equivalent DOT 4
Battery
- GYZ16H = 12v - 16Ah/10h.
ofrcboy
ofrcboy
501
572
Oregon
Thanks for the information I will print it out for future use. Thanks for the quick responce.
Reactions: Crazydcrc
267,547
@Hondasxs may want to add the image you posted elsewhere at the bottom of the original post. Will help easily confused people (like me) as a reference of which drain plug drains which item, Engine, DCT, or Sub-transmission.
franzw
franzw
277
249
pacific nothwest
Very useful information, thanks. I have a question, hope someone can enlighten my concerns. My new 1000-5 , when running down the road in auto, when it shifts gears there is also a kind of clunking noise coming from underneath in the rear? Please tell me this is normal.
Reactions: Lofar
Springer
Springer
312
234
Normal. You will hear the shift solenoid "clunk" just before it shifts to new gear.
ofrcboy
ofrcboy
501
572
Oregon
We need a solenoid noise suppressor or something.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
My shift solenoids seem to quieten down as I get more miles on the machine (at ~275 now). They also seem to quieten down once the machine is warmed up.
dweezil
5
meadview
Oh Thank God, i heard the clunking noise on the trail and was afraid i would have to walk home....
glad to know it's normal.
maybe mother-honda should put another yellow sticker on the machine alerting riders to the noise, they got a sticker for everything else !
267,547
@dweezil Welcome to the club. Congrats on your P1K, they do shift with authority and it is noticeable at first, as stated about it either quiets down some with break in or you just get used to it. I only had 60 mile son mine until last weekend where we put about 100 mile son it un and down hills doing a lot of shifting. I think once you get accustomed to it being normal you don't even think to pay attention to it.
Feel free to share some pictures of your ride and adventures.
Reactions: MuDSlinger
Plumber101010
Plumber101010
597
584
Western NC (Hayesville)
Excuse my ignorance, but is 75-90 gear oil ok where it calls for 80? I already own many quarts Amsoil severe gear for my Chevy truck. Sure it's fine for the 1000 but always like to make sure :)))
Reactions: JimK4343
W
WVbowhunter
0
WV
Engine Oil
Sub-Transmission
Differential Oil:
- Front
- Rear
Fuel
Coolant
- Capacity:
Spark Plug
Brake Fluid
Battery
Does the engine and DCT share oil from the same sump?
SquatchonHonda
0
Tampa, FL
Are there any other options for brake pads besides the honda brake pads? They wear very fast and they are very expensive...
franzw
franzw
277
249
pacific nothwest
Good question, how much are they to replace? I have 360 miles on my P 1000 D and my rears squeal when brakes applied.
