P1000 Pioneer 1000-6 Factory Accessory Switches
P
Pyro3825
Marshfield, WI
  1. 1000 6 Crew
Hi all. New owner of a 1000-6 and had a quick question regarding switches after I couldn't find an answer here. The 1000-6 comes with three unused (I think) switches and I believe they are terminated with plugs in this bundle of blue tape. Is that correct? If so, can someone link the corresponding plug from the HondaSXS store that I could use to connect to them. Also, are the switches already powered or would I run power in one side and accessory out the other side of the plug? Last question is the blue tape wrapped plug on the drivers side. That is the accessory on power that I can use to turn on a solenoid correct? Thanks in advance!
20230824 223421
20230824 223435
20230720 121607
Reactions: 540RA and Smitty335
priselay
priselay
5
7
  1. 1000 6 Crew
Factory switches are not backlit unable to see in the dark...Just FYI
