![Hondasxs](/data/avatars/m/0/58.jpg?1711993914)
This is a new item and I need to work on some instructions.
NOTE: I am looking for a simple install video for anyone interested. I will place a bounty of $50 store credit for a completed video.
Item link - Pre-Wired Relay Control Switch for AUX and Key-on usage. For Stinger, Cole Hersee or any.
Thank you for purchasing the Pre-Wired Relay Control Switch Harness.
![530ziPmyHPrJ G4f ZTSLJ9Aw923 h923 s noauthuser0 530ziPmyHPrJ G4f ZTSLJ9Aw923 h923 s noauthuser0](https://hondasxs.com/data/attachments/400/400472-ea0cf75bc2c150e80f4e191e9985631f.jpg)
This kit simplifies the wiring of an AUX key-off/key-on control switch for your master fuse box relay. Such as a Stinger or Cole Hersee.
The harness comes wired and tagged for easy installation but here we will go over each.
Thanks.
![NtAJYjLgHQSSyMiNPGsmKMgw1920 h865 s noauthuser0 NtAJYjLgHQSSyMiNPGsmKMgw1920 h865 s noauthuser0](https://hondasxs.com/data/attachments/400/400473-8a1d83b185f30c169e549c3ada6381ee.jpg)
![BsQvLCrGUMJWUp53vSIkjlgw1920 h865 s noauthuser0 BsQvLCrGUMJWUp53vSIkjlgw1920 h865 s noauthuser0](https://hondasxs.com/data/attachments/400/400475-aff9ef7f5ca9161da1e7422a17332e94.jpg)
![J ThyCZW5iojFA2ys8j vuAw1920 h865 s noauthuser0 J ThyCZW5iojFA2ys8j vuAw1920 h865 s noauthuser0](https://hondasxs.com/data/attachments/400/400476-722466d002b287bc592a364dd5628b22.jpg)
- Yellow wire - This needs a key-on source. Recommend tying into the ACC circuit. This is the key-on trigger source.
- Green long wire - This needs a ground. Any frame or battery ground will be fine. Running it to the fuse box ground bus works well.
- 2 Small post hoops - These go to the small post on the relay. For most relays, the polarity is irrelevant.
- Red wire with fuse - This goes on the large relay post, battery side. This is our hot constant trigger source.
- The Rocker Switch - Install it into the housing with the tab matching correctly
Thanks.
