RECALL - Power Steering Joint, 2017-2020 P700, 2016-2020 P1000 EPS Models Only
CGD
CGD
53
SE Missouri
I saw this thread on here but never received a notice from my dealer or Honda about the recall. Does that mean that my 2020 P1K5 isn't affected by this or should I buy the parts anyway ?
Reactions: TxDoc and ch33br0h
Paulie86314
Paulie86314
Arizona
I had my joint replacement done earlier this year Honda notified me of the recall on this
Reactions: TxDoc
ch33br0h
ch33br0h
130
369
Jardín, Antioquia - Colombia, South America!
guess it depends on your comfort level.
if you follow the PDF and the video you can do a very fast check on your own and then order parts if needed.
Reactions: TxDoc and TripleB
CGD
CGD
53
SE Missouri
I'm not too worried about actually doing the work. I was just wondering if maybe mine wasn't affected by the recall since I hadn't been notified.
Reactions: TxDoc
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
If you were close to us we would do this while you wait.
No dealer should be that busy.
Thanks man. I scheduled early summer and at the time they told me if it needed the work it would probably be about a week for parts to come in and I ended up having something come up and had to cancel and just never rescheduled. I will call to see if by chance they have the parts in house and if so will drop it off. Just dont want to get it broke down and need parts and then all of a sudden they be on back order like everything else in the goofy world we are all in right now
Reactions: TxDoc
HondaTech
We keep atleast 10 joints and 30 bolts/washers in stock at all times.
Any dealer who doesn't stock recall parts, especially for a recall this size is just stupid.
ch33br0h
ch33br0h
130
369
Knuckle, bolts and washers arrived this morning,
Full on OCD reviewing this thread, the PDF and the video for the last 4 weeks!
I was super prepared!
Took me longer to learn how to use my torque wrench than the time it took for me to get the new parts in.
big thank you to all the amazing people that continue to share info here!
42,130
Make sure you check this over the next few rides. I used a torque wrench as well, but the spec was near the bottom of the range, which may have affected the accuracy. A ride or two and there was a touch of slop on the splines (may have always been there). After that I said screw the torque wrench and just hit them a regular wrench and some muscle. No more play since.
livefromthetree
livefromthetree
466
1,309
We keep at least 10 joints and 30 bolts/washers in stock at all times.
Update...
My dealer did not keep the parts in (maybe they had the bolts and washers but not fuel pump, not sure on what they had to order), but did tell me last week they would order them and call. Called me on Thursday, I hauled it over Friday morning and it was ready Friday after lunch. Fuel pump and steering recalls checked off.
Gotta give credit to them for following up and doing as they promised. Westside Honda in Evansville IN....good job.
O
ob1jeeper
97
279
53
Arizona
Just found this while seeking information relative to help for my 2016 P1000-5's EPS which without warning quits working as PS occasionally, then just as suddenly begins working again. This can occur as much as miles and days apart, or sometimes within minutes, but most times requires the ignition to be shut off, and let sit for a few minutes before restarting (which does not always work either)...
Plan on pulling the lower bolt for inspection, but thought I'd ask here for any thoughts of what I should be looking for? Thanks.
HondaTech
Whneit stops working are there any lights on the dash that pop up?
Stock tires? Stock Arms?
O
ob1jeeper
97
279
53
Arizona
Without pulling codes, it would be hard to tell. But the recall isnt the issue.
Check battery cables first, then see what codes you have.
I tried that initially, but the cables were tight and clean. However, to be sure, I disconnected both batteries, cleaned terminals and checked them at BOTH ends ... ( I did not find any evidence of oxidation, nor looseness) and re-installed the cables. Issue still pops up occasionally.
Don't have a code reader, so I guess the next step is to take it to a dealer to get codes read...
Reactions: TxDoc
HondaTech
Codes are readable with the 4 pin red connector under the seat.
Short the Green and Brown/Red wires and turn the key on. Watch the EPS light and itll blink.
Long blinks are 10, short is 1.
So 2 long and 5 short would be code 25.
O
ob1jeeper
97
279
53
Arizona
Thanks for that info. Will futz with it tomorrow... ;) I will search the site to see if there is a code explanation sheet here... ;)
Reactions: TxDoc
Travis R
Travis R
135
441
Southeast Louisiana
The steering broke on my 2016 Pioneer 1000-3 EPS tonight and after reading this thread, I’m 100% confident this recall is the problem. All I can say is THANK GOD I was going in slow in reverse when the steering gave out!!
The u-joint/knuckle assembly spins freely on the steering shaft!
How do I go about getting this fixed? What should I tell my local dealer? I bought the side x side used from an individual. Should I call Honda first?
THANK YOU to whoever posted this thread, THANK GOD I wasn’t driving and wrecked when the steering broke, and THANK GOD for Hondasxs.com!!!
