P1000m3 Remote Rez shocks
DixieDeerBlinds
Brandon Mississippi
I have a 2020 p1k -3 deluxe with the highlighter 2.5” bracket lift. The ride is horrible with the stock shocks being reposition and under a greater load.
My 70 yr old father has a 2019 P1k-3 LE with the fox shocks, no lift, and has a smooth ride.
What remote reservoir shocks would work with the highlighter that would get close to the same ride as my fathers LE
Reactions: TxDoc
tdhanses
tdhanses
1,044
3,553
Kansas
Get rid of the lift, get Fox shocks and upgrade the springs to 250lbs front 300lbs rear, set your preload to 1.5” all around which will give you decent lift and it’ll ride better then your fathers. Here is mine with no lift but the 30’s add some as well. Ride is amazing. My ground clearance is 16” to bottom of skid plate in the front and almost 17” to bottom of skid plate in the rear.
F891E02E 94A4 410E A8BE 24BA207A8EE7
8B043917 BA87 4E3A 8775 F1BB9F69DC17
C1EB411F 3046 42A1 9905 F41BCF3E26A9
DixieDeerBlinds
Brandon Mississippi
View attachment 250963View attachment 250964View attachment 250965
Thanks!
Reactions: Remington
Elvis8310
Elvis8310
54
103
Edmond, Oklahoma
Where did you get the new springs from?
Reactions: WagginTail
WagginTail
WagginTail
1,484
5,482
SC
Look up viper springs on Amazon. Summit racing has some too. You need 14" long. 2.5" diameter for front and 3" diameter for rear
russknight
russknight
1,910
7,507
Perry Florida
Forget the buggy, I need more info on the weapon.
