P1000 Tire questions
Jeffro
106
47
Louisiana
I'm about ready to get a new set of tires and wheels and trying to decide on size. I know I want Blackwater Evolution and I know I want 28" tires on 14" wheels but I'm trying to decide if I should go with 10" wide all around or 9" in front and 11" in back. Will the 10" rub with no lift? If so then there's my answer but I've seen mixed answers on that. I think the 10" looks better but don't want to worry about rubbing.
Any advantages to 9" and 11" over 10" all around?
Also, if I get 14x7 with 5 +2 offset, the fronts will stick out further than the rears right? Is that a problem and do I need 1 inch spacers on the back to keep them lined up?
I would get the 10's all the way around so you can rotate. You should not have any problems with rubbing. The 5-2 wheels would be a good choice. It will be about 1 inch wider in the front but it won't hurt anything. Some people choose to get 1 inch spacers for the rear so that it evens it out.
(Delton) "I HATE light scratches too. Makes me think I left some fun on the table. So I go back out there and cover them up with deep scratches. Works every time lol."
208,029
Can you not get 4-3 wheels for the back, that would knock out rotating?
Reactions: Eltobgi
208,029
I have 28x10 on front and 28x11 on back. On stock deluxe wheels they didn't rub before my bracket lift. I
Like the 10 on front. 9 are too skinny and 11 look good on back
I run Trail Armor skids, think the front would rub with 10's?
Sure could!
Reactions: Eltobgi
208,029
What brand of tire you running and tread pattern?
208,029
Sure could!
You sound like Mr Rogers, sure I knew you could, HA!
Reactions: joeymt33
208,029
What bracket lift you running, are you happy with them? I've got to get off my butt and get some shocks and lift kit ordered and tires, do it all at one time.
Reactions: Bayouownbeer
208,029
How about Moto Hammer tires?
Bayouownbeer
Bayouownbeer
789
1,091
Chauvin LA
I don't think so I have the blackwaters. I have the full plastic skids as well. I had the 28x10 and 28x11 before the bracket lift and with the skids and didn't have any rubing thats with deluxe wheels
Bayouownbeer
Bayouownbeer
789
1,091
Chauvin LA
Superlift 2.5 inch I believe it is bracket lift. Yeah I have no complaints.
208,029
Mr Rogers was a decorated Navy Seal. I wouldn't mind being associated with him one bit lol.
Really, I didn't know that. I listened to a interview with him, he was very intelligent man.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I don't remember how many confirmed kills (20 something) he had in Vietnam. He always wore sweaters to cover the tats on his arms. He told a reporter years ago he started the Mr. Rogers thing as a kind of penance for some of the things he had done. I have great respect for the man.
208,029
Anyhoo.....Back to tires lol
Mr Rogers would probably run set set with a less aggressive tread pattern. Any body running the Moto Hammer tires?
I considered 28x11 all the way around how much space is there at full lock/compression on the front?
Reactions: chadbo
Bayouownbeer
Bayouownbeer
789
1,091
Chauvin LA
I'm not sure on that. I'd have to check on Wednesday. You have bracket lift?
