P500 UFF Farm Build
U
UFF
27
215
Thanks, just finished the back up bolt lights.
91A75597 E63E 45BA 9EC8 86D52695B3FD
71D788A0 99B9 4748 8A77 EF717B00AD32
160,062
Heads up, the bolts that go into the side of the light like to work themselves loose. Had mine hanging by a thread bouncing in front of me down the trail. Several of us have had the problem and yrs ago @jak9922 came up with a fix. Just running a threaded rod between the brackets solves the issue. I've done it to two lights now.
Light BarVisor
Bigtee
Bigtee
556
1,213
Grayson, KY
View attachment 322779View attachment 322780
It’s a good modification, I did it to mine also.
BA591FE2 EE94 477C A3E3 7E47BCB66862
U
UFF
27
215
Hitch installed. Lays against the frame all the way up. Used all four factory bolts and added two more at the top with inside spacers. 3/6” steel and 1/4 x 1” angle iron as braces. Used a hole saw to allow round pipe to to through. You have to cut the holes larger than the pipe to allow room for where the pipes are welded to the frame and allow the plate to lay flat against the frame.
B6D80BB9 7A25 4799 AFAF C638C582E725
4972A9B4 A44A 418E AA9A C65355783DEA
