utv solution portal bracket fixed
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
so as most know. i cut my brackets up and redid them. just put 60 miles on them yesterday. pulled 3 guys out by holding the brakes and sliding(the same thing that bent them before) didnt even move the upper brackets at all. the whole deal with them bending was no weld on the bottom side of the upper ball joint bracket
Russ989
Russ989
22,588
146,743
At least you’ve got it figured out now. I guess the only thing left to do is ride!
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
yep. did some good off camber riding last night. following 4 wheeler trails. at river run. im freaking sore today. cant tell you how many times i had to 3 wheel the thing. got stuck once. just trying a hole ole boy had to get pulled out of on 35s.
