BRed What are the causes of engine smoke and oil consumption?
Robobrainiac
Robobrainiac
2,462
8,589
It looks like you got the problem solved. I can't tell you how many times something new from name brand or off brand can be good and/or bad. I put a camshaft, new lifters, and rockers on an 08 jeep Cherokee on the right hand side on Monday. Got it back together and it was clicking like crazy. Most forward lifter on the passenger side was making the noise. Shoved the old rocker and lifter back in and it's quiet as can be now. A few months ago I did the top end on my 300ex. Hot cams camshaft, wiseco higher compression piston, with wiseco gaskets, and oe timing chain and guides. Had the head checked, replaced seals. seated valves, and jug honed. After firing it up you could watch oil leak from the new head gasket. Ran like a champ but would slightly leak oil. I bought a tusk complete gasket set when I bought the machine just so I always had gaskets if needed. I didn't want to wait for shipping so I threw the tusk head gasket in and it's been perfect ever since. Sometimes things just turn out sideways.
Reactions: fmjnax and Mudwing
ByronM
ByronM
173
347
St Charles, Il
Well I will keep following. I my opinion valves with poor seating don’t burn oil, rings and valve seals will.
seems like you have good compression so a new head with the proper clearances on the valve guilds should fix it.
Good luck
Reactions: fmjnax
Jerryg
Jerryg
10,743
86,781
NEPA
I have had more than one cylinder head in my day have a crack that couldn't be seen with the naked eye.
Hopefully the new head solves your problem, but make sure you know the correct procedure for valve adjustment.
Reactions: fmjnax
F
fmjnax
74
127
Texas
  1. Big Red
Looks like the new head assembly solved the problem. Had a little bit of smoke for a half hour or so that worried me, but must have just been burn-off and maybe the new rings still seating themselves. Seems to be smoke free now and everything looks good *knock on wood*
Thanks everyone for the great input on this. I learned A LOT!!!
Mudwing
Mudwing
36,959
306,563
The Mud holes
Quite the journey you took. I’m glad you finally got it. I really appreciate you posting. Thanks. 😎
