P1000 Wheel/Tire pics!
G
GEM1N1998
36
62
Lee's Summit
Out with the 28’s. In with the 32’s.
2B3730C7 B89A 44E7 BA42 8C6FD4143A5B 0DCB4C87 4A00 479A 9752 62951435343D
HBarlow
HBarlow
1,614
5,997
Daniels, WV
My wheel & tire choice was made after posting questions and reading many member posts with photos. They're conservative like I am.
I bought a set of Pioneer LE take-off 14" wheels and tires from Shawnee Powersports' ebay store and a set of four Tensor Regulator tires ins size 28x10x14 and a pair of RB3 1" spacers for the rear hubs.
I prefer using Honda oem wheels rather than the popular, "sexy", Chicom wheels many are using. The 28" tires look much more appropriate on the buggy, fill the wheel wells, and are "no contact." The tires require no suspension mods and do not contact any suspension or body parts.
IMG 1948 IMG 1951 IMG 1953
Robobrainiac
Robobrainiac
2,472
8,644
Vision 544 BOLT 5+2, 14x7, +38mm, beadlock wheels with 28x10-14 SuperATV Intimidator Tires.
Machine has high lifter arms, high lifter 2.5" lift, Southern Powersports 1" spacer in front and 2" spacer on rear. Has no rub issues.
Prior to the lift and spacers the tires would rub the inner fender at full lock under compression. I later realized the tires were rubbing slightly on the front strut bolts while turning to the lock.
I did not install the high lifter steering stops with the control arms. I like the factory turning radius and I know I should be fine as long as I don't turn to the lock while diff locked.
IMG 20210723 102745 IMG 20201208 114708 IMG 20201208 114722 IMG 20201208 192148 IMG 20201209 072343 IMG 20201209 074826 IMG 20201209 104511
Isaiah
Isaiah
2,191
6,964
Altamont TN
Update with these?
I run those tires in 32s also. They perform well in rock and decent in mud but it's not designed to be a mud tire lol. They wear fast on the pavement. That and I wish they was a little bit better in mud are my only complaints 20210819 1720072
20210710 141842
Dirtstiffs-1000
Dirtstiffs-1000
1,565
5,708
hondasxs.com
View attachment 291033 View attachment 291034 View attachment 291035
The LE & Deluxe rims are made in China.
Reactions: Robobrainiac
