P1000m5 Which Battery for dual battery set up 2022
A
ADVBUM
64
245
Arkansas
I have been reading dual battery set up threads. Many different ways of people doing it. I dont see recommendations for what battery to use. What battery has been the better option? Is there a parts list thread for the dual battery set up? TY
Reactions: ChadD and TxDoc
Scoop
Scoop
4,416
17,003
  3. Talon R LV
There are tons of threads that include specific battery recommendations. I have a Mighty Max in my P1K5 and a Deka in the Talon. See my build threads for specific part numbers. Oh, search is your friend, too.
Robobrainiac
Robobrainiac
2,475
8,664
What is your preference of placement because I feel like that changes the recommendations. My auxillary battery is a full size marine under my driver seat.
Reactions: ChadD
Johnny5isalive
Iowa
Mighty Max also
12V 26AH Battery Replacement for Odyssey PC925 https://www.amazon.com/dp/B01N0P2O2O?tag=sxsweb24-20
B01N0P2O2O
Working on it now 😀
IMG 8481
Reactions: ChadD and ADVBUM
Hillbillytnt
Hillbillytnt
525
1,943
Ky
If your going under the hood gravity will hold it for most rides but I used a couple big zip ties on my 19 model to hold it.
Reactions: ChadD
Robobrainiac
Robobrainiac
2,475
8,664
ordered, Thank you. How did you secure the battery?
Should be post 15
Reactions: Scoop
bumperm
bumperm
1,856
6,670
Gardnerville, NV
I guess there are several ways that work. The battery needs to be secured well enough that it won't come loose in the rough stuff or if you turn turtle - (don't do that).
I used a nylon strap, one of the ones with a simple cam type buckle. Cut to length, secured the strap on each side of the battery well using hot melt glue (I tested this first on a scrap of plastic to measure adhesion strength - it's strong. I also put some closed cell foam between batter and box so the straps compress the strap to keep everything snug and vibration free. Sorry, no pics, they're on my other computer that's gone bonkers. (I hate computers)
