P700 Which pre-wired winch rocker?
CardinalSxS
Minnesota
Hi all - recent joiner to the forum...have been reading and reading and reading... So many mods, so little time. :)
So I'm just getting started and want to add a rocker switch for my Warn winch...trying to figure out which one will work with my setup. Here are the two that I believe could work, and here's a pic from underneath my hood. Thoughts? Thanks in advance.
Image1 Image0
Hillbillytnt
Hillbillytnt
523
1,926
Ky
View attachment 358403 View attachment 358404
Check out the club store. I’m running the one they sell. Should work on any of them.
5,091
22,874
I used this one from the club store for my Talon and my contactor looks just like yours. All it takes is 4 wires - 1. Switched hot. 2. Ground. 3. To one end of the 3 contactor terminals. 4. To the other end of the 3 contactor terminals. The middle brown/tan contactor wire is left alone. Double tap spade connectors are included in the kit.
The black and green wires coming in from the bottom of the photo are directly from the In/Out winch switch.
1665522111633
1665522280974
208,029
The top one, "for factory winch," is if you have the OEM WARN/HONDA winch installed.
The bottom one is if you don't and just need a rocker.
Remind me to talk to you about the difference between the Honda winch wiring and the regular winch wiring, it'll be later when I find a top winch bumper mount.
Reactions: Buggyman
CardinalSxS
Minnesota
This is great - really appreciate the pics, too. Just made the purchase from the store. Thanks!
Reactions: WagginTail
