breakdown kit
sxs2015
sxs2015
203
Maine USA
Ok
Well who has one? and what is in it, where do you keep it??
1.tire pump
2.tire plugs
3.jack
4. spare tire?
5.lug wrench
63,391
Looking into your question. I'm now confused. I read a Phillips screwdriver will release the emergency bypass and put it (IN) to limp mode, second gear. But nothing on getting it out when it automatically goes into limp. Except finding and correcting the issue.
May be a good idea to start a post about it sometime as it will be good knowledge to know on the trail.
There is no automatic limp mode it was a snarky comment about Can-Am
Slipped, no matter what gear. Wouldn't fully engage until RPMs were up.
63,391
Ok. I think that's what the emergancy mode is for. If you have engaged it, I think it would been stuck in second..... I think.
You can engage 2nd manually using a Phillips screwdriver, if there is a problem with the ECM. Haven't tried to use it in 2nd in reverse haven't needed to.
sxs2015
sxs2015
203
Maine USA
All one needs is a HONDA. and a tire pump and a can of slim???
