P1000 Pioneer 1000 floor and firewall protection
I started this evening making protective plates for the front passengers. Let me know what you think please. This has been quite easy and I made these three pieces in less than an hour before I called it quits.
I started with some 24"x24"X1/4" UHMW
2280dd2f922748ddfcadc16e53ec618e
97faf1301dd63f100aa83ea19d09ed93
Here is one section that needs to be protected. It's on the bottom passenger side
2f047b8df4dbf3f4e3d0a2b11018294c
I mocked up some cardboard because it's cheaper than UHMW.
Cf914abe9ae97dfae50092ba517ebaa2
Turned out ok
2cbafe29ce0bfe9dcb03ea07582aa4d2
I need some input on how to connect it. Right now, I think I will use screws from the inside and screw them into the UHMW. What do y'all think? Can't glue it, nor do I want to do that. The UHMW is too thick for the plastic rivets.
Next panel is just above the first one I did.
Bb421aa3cb769eadd333c83b457f3bc5
Same story here, cardboard is cheaper
5d899a4ed41421479794f18665ee5bee
Here is what I will call finished.
Bc10fb4560c1eda951bc38d1c64efb6c
I was going to bend it or take it higher but I'd like to leave it open so it's not a mud trap.
The last piece I made tonight goes over the checker board.
303dd47e4366cf90a3721f604bee4938
This one I had to bend. There's no way around this one, it will be a mud trap. If I mount it with screws, I can remove it easily but doubt I ever will.
Maybe I'll get the rest of it done tomorrow. I wish I could make it out of one sheet but I can't bend this stuff that much. I may scrap this idea and make it out of sheet metal and weld all 4 pieces together. Not sure yet. I like that the 4 separate pieces have "clean out" gaps where they meet though.
Here's all three pieces
E60ba3b11d699f90e0256c218d9772d6
That bolt has a large head and could have a lock nut in the wheel well side.
Reactions: Lady01 and Eltobgi
272,176
You may try forming one piece out of 1/8" thick aluminum for each side.. Use spray on bed liner as a finish and secure it with1/4" x 3/4" long carriage bolts using nylock nuts.
Here's another screw to to try. I like this one ok too
C52f2cbe5ce23a40859b5c7ee5d2ebf6
Reactions: Lady01
I had hopes for that with plastic but these angles meet at one point and come from different directions so there will be some cutting and over lapping if metal is used. It sounded too complicated for me when I could just weld all pieces together.
I hope this is a permanent addition but I'm sure a skilled fabricator will show me how this is done pretty soon. Who's the guy with the blue custom P500? I need him to help me form some metal.
Reactions: Lady01
Eltobgi
Eltobgi
4,599
15,186
North Dakota
That is exactly why I was thinking, but couldn't think of the name for them. Could heat em up a bit to melt skid just enough to sit flush.
Reactions: Lady01
322,690
great job! Needs to be done!
Reactions: Lady01
I've been too busy with other stuff lately but finally got around to finishing the passenger side.
85640086270585b6255b1f6bccf744a5
It over laps in this area so no stick can squeeze through.
A34e9f996d1520fe6b7a6f1d8bb1468f
I left a crack here so I can clean it out.
B89f2d97e6d909d31902b99cef2b9a5d
Not sure what to think about right now. It looks kinda crappy but I don't see any stick going though it.
322,690
Looks good. That was needed
Sent from iPhone
Reactions: Lady01
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Could you post a pic of the cab interior bolts to show what that side looks like. Thanks
Here's the inside. Black screws would have been better but I'm not one to care too much about looks. I guess I could paint them or change them out.
Cb9c0968554fcf2c1854d46df455ca5b
I used elevator bolts where the most pressure is and self drilling screws with 10-24 thread so I could put lock nuts on it.
44da16d50e99464487769b4172b8d36f
Reactions: Lady01, pct and 500
Eltobgi
Eltobgi
4,599
15,186
North Dakota
That looks real clean. I like it. How much did you spend in materials for the entire install?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Just now came upon this thread. Nice job! Especially love the part that covers up those squares from hell lol. Clean looking and I'm sure very strong. Kinda sad to see members with sticks poking through. Poor design.
BIGRACK
BIGRACK
202
376
Dayton Tenn
Good job Joy .This will be my next mod.I almost had a stick come thru on passenger side yesterday riding on my property. Got stopped just in time! I like the UHMW I made my skid out of 1/2 inch. I think I'm going to try sheet metal cut it out and then weld. The elevator bolt good idea. Again good job all pioneer owners should consider this mod!
