P1000 1000-5 won’t get out of low gear
DawgU
DawgU
Oakland TN
Duck hunting so it’s gotten cold and wet. Can force shift lever to high or reverse, but it won’t come out of low. Any ideas?
Reactions: ChadD
Hello_Darkness
Hello_Darkness
675
2,742
Just to the right of nowhere
Possibly broken shift cable on the sub trans end. I've seen the plastic sleeve in the rubber boot break and the cable just bends instead of moving the arm.
Take the front seat off and look at the shift arm, see it the cable is being moved on that end. You can also shift the arm manually if the cable is indeed broken.
Reactions: ChadD
T
tbounds02
48
119
Ms
  1. Looking to buy
If you check for ice on cable and shift links. Don’t force it from leaver . If it is warm enough to have thawed out and still won’t shift cables most likely cables problem
Reactions: ChadD
DawgU
DawgU
Oakland TN
Thank you!
DawgU
DawgU
Oakland TN
Thank you!
Teammontana
Teammontana
Arkansas
Had a similar problem last year in Colorado. Eventually took the negative cable off for a few minutes and everything went back to normal.
