2024 Talon Tail Light
Cuffy Meigs
11
11
FW Indiana
  1. Talon X LV
Can anyone help me on removing tail light? Added a turn signal kit and had to remove both tail lights. The ball and stem system Honda uses is difficult to remove. Instructions for kit said to pull out bottom, that is it. I did this and it bent the top stem. I used heat to straighten and reinstalled after adding the wiring harness I needed to. I later need to remove one and it broke at the stem on the top ball/stem. Used soap the lubricate the rubber grommet, pushed as hard as I could on ball with a small nut driver. Thru bouts of cussin Honda engineers, I tried the method on instructions and guess the stem had weakened. Things ain't cheap, a benjamin for one OEM ! Anyone help me with recommendations on how to do this? Greatly appreciated.
Talon tail light
  • Sad
Reactions: CID
Hello_Darkness
Hello_Darkness
677
2,745
Just to the right of nowhere
Lube the grommet, we use silicone spray, the use a socket smaller than the ball end and push.
Make sure to go evenly, not one side then the other.
Reactions: JNo323 and CID
