What is the max amp draw for the cigarette type plug?I was wanting to get a small air compressor.
M Moose308 Well-Known Member Jun 16, 2015 386 289 63 Aug 2, 2015 #1 What is the max amp draw for the cigarette type plug?I was wanting to get a small air compressor. Reactions: 100Acre
jak9922 hot headed wopolock Vendor Lifetime Member Jun 2, 2015 3,296 5,682 113 pittstown ny Aug 2, 2015 #2 You will be good with the plug in style compressor im not sure what the fuse it on the p5 but ive used my compressor few times with no trouble
M Moose308 Well-Known Member Jun 16, 2015 386 289 63 Aug 2, 2015 #3 jak9922 said: You will be good with the plug in style compressor im not sure what the fuse it on the p5 but ive used my compressor few times with no trouble Click to expand... What kind and use using Jak?
JollyJoker Active Member Jan 19, 2015 92 192 33 Minnesota Ownership 500 Aug 2, 2015 #4 I think I read in the manual it was a 10 amp fuse. Reactions: Moose308 and Hondasxs
jak9922 hot headed wopolock Vendor Lifetime Member Jun 2, 2015 3,296 5,682 113 pittstown ny Aug 2, 2015 #5 Husky pro from homedepot Reactions: Moose308
M Moose308 Well-Known Member Jun 16, 2015 386 289 63 Aug 2, 2015 #6 jak9922 said: Husky pro from homedepot Click to expand... Thanks
jak9922 hot headed wopolock Vendor Lifetime Member Jun 2, 2015 3,296 5,682 113 pittstown ny Aug 2, 2015 #7 http://www.homedepot.com/p/Husky-12-Volt-Inflator-HD12A/203356023. Wow some ppl gave it bad reviews but ive had it almost a year use it few times never had a prob
M Moose308 Well-Known Member Jun 16, 2015 386 289 63 Aug 2, 2015 #8 jak9922 said: http://www.homedepot.com/p/Husky-12-Volt-Inflator-HD12A/203356023. Wow some ppl gave it bad reviews but ive had it almost a year use it few times never had a prob Click to expand... Don't fix it if it ain't broke.
JACKAL Ancient Honda fanboi Moderator Lifetime Member Supporting Member Club Contributor Jun 11, 2015 39,667 270,316 113 Pioneer, TN Ownership Other Brand1000-5 Aug 2, 2015 #9 Those small 12v compressors can be a godsend out in the boonies under the right circumstances. Not to mention able to air up inner tubes to help float the cooler when tubing down the river Reactions: 100Acre, Moose308 and p500fan
