Has installed a super atv poly rear window. Wanting to know if i could still use my rear nets with it??
@SuperATV would know.Has installed a super atv poly rear window. Wanting to know if i could still use my rear nets with it??
Have you met @JTW or @GuyOnABuffalo?I can read the decription. Im wanting to know why? I will just have to figure out how to make it work
Because it was designed to be used without the rear nets. Didn't you read the description ?I can read the decription. Im wanting to know why? I will just have to figure out how to make it work
You could try liquid nails instead of brackets?I can read the decription. Im wanting to know why? I will just have to figure out how to make it work
Or you could remove all the points where the nets attach to the rear ROPS and try that?I can read the decription. Im wanting to know why? I will just have to figure out how to make it work
Zip ties?Or you could remove all the points where the nets attach to the rear ROPS and try that?
No just free float it.Zip ties?
Whack, whack, whack and it will!I can read the decription. Im wanting to know why? I will just have to figure out how to make it work
Pics or it didn’t happenI installed that rear window on my 1000-5 a couple weekends ago. There isn’t enough room for the screws that hold the back of the net on. I did end up using 2 zip ties and got them through the bracket.
So yes, with a couple zip ties you can make the rear nets still work.
