Battery seems too weak for my 1000-5.
O
old-school
5
11
Even though my battery is new, it seems weak when starting my 1000-5. Are some batteries better than others?
I added a boat battery box under the driver's seat and put in the biggest car starting battery that would fit. I believe it is a 750 cca sealed battery. Anchored the box to the frame and filled the sides with closed cell spray foam to seal out water, mud, dirt, etc.
Be sure to use a proper size wire ga. for the length of cable needed.
I did this in 2018 and no problems yet winter plowing snow or summer. I use it yr. around.
Old School
KTM3040
KTM3040
21
36
Illinois
Old School
Great idea...thank you!
Regulator
5
SW Georgia
Original Battery lasted 5 yrs. Ordered same battery off internet it lasted 5 months before it would buzz the solenoid. I went to Honda dealer there original batterys were backordered. They were AGM Yussa battery's. They had the cheaper battery's you had to put the acid in. I bought one and the Pioneer never cranked as fast as it did. Charged both battery's before using. The jury is still out,but as of now no more AGM battery's for me.
Justhere
Durham, NC
I did similar as car battery installer. However I parralled a small car battery with existing battery. Still undecided about where to permanently mount. I have a pioneer 700-4 and no bigger battery will fit.
Rayger143
Rayger143
3,096
27,188
Winfield, BC Canada
They all crank slow when cold
I agree. Mine has always seemed weak since I got it but it has always started. Keep a maintainer on it in winter months and it still cranks slow but always starts.
Reactions: KTM3040
rickoshea
mine lasted a little over 2 years with only the winch as an acc.not going with the stock one again.
Reactions: Rayger143
