P1000 Car Seats in Pioneer 1000-5 rear seats
Carleton
Carleton
150
133
Hi Everyone,
I'm looking for a better way to mount car seats in the rear seats of The Family Rig and was hoping you could share ideas.
I've seen Joey and others running car seats back there. Give me some ideas!
ToddACimer
ToddACimer
Pioneer 1005-2
3,678
15,560
Oshkosh, Wi
I run a ratchet straps around the rear seat back and hook the hooks together. I hook the car seat top buckle to get cargo tiedown.
Reactions: moparornocar
Carleton
Carleton
150
133
Sounds like a great idea, THANKS..
So you run the top strap up over the seat back and down to the strap? Does this hold the seat from going forward pretty well?
ToddACimer
ToddACimer
Pioneer 1005-2
3,678
15,560
Oshkosh, Wi
I loop the ratchet straps through the car seat and around the seat back which holds it in the seat. I then run the car seat upper strap over the seat back and down to the rear cargo box tie down. This holds the top of the car seat to the top of the seat back
208,726
This I gotta see, pic please!
Hi Everyone,
Remove all the padding from the seat and then fold the seatbelt buckles out and the car seats will fit much better. Take the other guys advice on using ratchet straps. That’s what I do.
Carleton
Carleton
150
133
Interesting on removing the padding.. Do you remove the bottom and back padding?
You are the Guru Joey
ToddACimer
ToddACimer
Pioneer 1005-2
3,678
15,560
Oshkosh, Wi
This is the best pic I have in the back.
18033958 10100677558294607 6706097820124999363 n
Downs807
Downs807
39
116
Kentucky
I drilled a 1/2 hole in the frame backing to latch the car seat tie downs too. Just like you would in the car and like others said pull the rear strap over and latch to the cargo hook. 96f6c049c6cf2e9b980b7f7f1d37b4ed0e3f7f979faee7b40962fb7405da58c4
Reactions: JTW
Carleton
Carleton
150
133
I drilled a 1/2 hole in the frame backing to latch the car seat tie downs too. Just like you would in the car and like others said pull the rear strap over and latch to the cargo hook. View attachment 56386View attachment 56387
Awesome, so you don't even use ratchet straps, just the standard car seat straps? I like that. 1/2 inch"?
Reactions: JTW
208,726
Reactions: Downs807
Have you all put these mods thru strict government saftey testing?
Yes the back and the bottom removal really helped with stability. Of coarse that’s for our brand of car seat so your results may be different. Give it a shot and see what happens.
