Dipstick not seating all the way
T
TAzLON36
5
9
Arizona
  1. Talon X4
So just picked up a 1000x4 LV, second owner first guy put 91 miles on it so I did the first service. Changed all fluids filters everything was good to go. Went for a little 3 mile cruise came back to check oil levels and now I can get the dipstick to seat all the way... Grabs a bit two threads and locks up. Threads looks a little booged, did I cross thread it somehow?
Mopower58
Mopower58
Unburdened by what has been!
79,894
709,306
Crystal Springs,Ms.
Not sure about the Talon but I do remember Pioneers having issues with cross threaded dipsticks. The Talon and Pioneer are probably similar.
Reactions: Isaiah
272,178
It is possible the end of the dipstick is not in the correct position, it will do exactly as described when that way. Pull it out and insert at the exact angle that it screws in.
208,726
Should tell by looking at the threads of the dipstick?
Reactions: Isaiah
T
TAzLON36
5
9
Arizona
  1. Talon X4
Yeah, I talked to a guy at the dealer and he said same thing... had to order new dipstick. Crazy part is I didn’t put any real force into. It threaded in easy and just stopped. Granted I could have tightened it more than I thought.
906UP
906UP
14,275
135,422
da Yoop
It's fairly common if you check them while they're warm/hot. The plastic gets a little soft. One in our group had the same issue.
Reactions: Mudwing and Isaiah
T
TAzLON36
5
9
Arizona
  1. Talon X4
That’s exactly what happened, checked it while it was hot... stupid mistake, figured the plastic wouldn’t soften that easy lol
New to sxs so never had to deal with that on my atvs, just plastic top on the dipstick not plastic threads.
Reactions: Isaiah
5,433
24,951
This has happened to me several times in my Talon. Apparently there's something 'down there' 🤔 that will tip the dipstick if you don't get it straight in. You can see that it's not straight if you look but it's easy to think all is well.
T
TAzLON36
5
9
Arizona
  1. Talon X4
Yeah I can feel whatever is down there, kind of odd that they set it up that way... you’d think they would have it set with zero obstruction 🤷🏽‍♂️
Cooperjames
Indiana
I have exactly the same issue. Did you have to replace the dipstick?
5,433
24,951
They’re plastic threads, if you can get it started straight the alum case threads will fix them. The only reasons you’d have to replace it - 1. The threads are too heavily damaged. 2. It leaks.
JCBuckster
JCBuckster
57
205
Hurricane Utah
I cross threaded the dip stick on my Pioneer 1000. Was easy to do. I kept smelling this burning smell when I was on a long ride. like burnt wires. I would stop and check out the machine, but didn't find anything. When I got it home and was cleaning it up I found oil had leaked out between the cross threaded stick. the crankcase is pressurized, so no dirt got in, lost about half a quart. But now I am carful with those dip sticks.
Baja Bronco
7
Tucson Arizona
  1. Talon X4 LV
I had the same issue. I have a 2020 Honda Talon 10004X LIVE Valve. Changed the oil, threaded the dip stick back in with no apparent problem. Went for a test drive and afterwards I attempted to check my oil level and had a tuff time trying to remove the dip stick. When I tried to reinstall the dip stick it would not go in smoothly. I checked the threads and one of the threads was split. After cleaning up the threads, I was able to get the dip stick re-seated. As mentioned above, the engine was hot when I checked my oil. I never thought this would be a problem.
