P1000 engine quits after 2 hr, no restart
G
GoneFishen
10
nevada utah
unit under warranty, 1600 miles 2020 1000 5.
took to dealer. found out some info for this site.
1-2016 machines had bad injector harness connections, missfire or no start
2- 2018 machines ecm board breaking due to heat issues under drives seat only in hot locations like where i am.
3- 2020 machines like mine, bending ecm board causing engine quiting. hot desert locations like mine. ALSO,
4- fuel pump problems possible. mine did this after 2 to 2.5 hours driving in mountains on low speed traavel from 5 to 22 mph. engine would just quit. i had placed plastic loom wrap on fuel line, always had over 1/2 to 3/4 fuel level in tank, engine fan was working, engine temperature was 2 bars.
REPAIR, under warranty---fuel pump removal, fuel pump disassemble and gear assembly replaced. unit now performs even after 3 hour trail ride.
