Headlamps innopertive
meservais
meservais
12
Baileys Harbor, Wi
Can anyone help? New to this form and hope I am posting to the correct place. have a 21 p1005, Just installed 2nd battery with isolator kit, (per Robert Sparre video and wire diagram) all is working great except now front headlamps innopertive? have dash lamps and tail lamps, checked fuses- no power to the 3rd fuse which is 10a start - which according to wire diagram looks like it feeds the headlamp relay, pulled fuse block up and it looks like it is a yellow wire with red stripe, any idea where that wire gets its power from? (I took a look at both the blue headlamp relays, and switched their positions and that did not help)
Thanks for any help!
HondaTech
Yellow/red wire gets power from ignition switch.
That wire will only have power when cranking, it doesn't feed the headlight relay its used to shut the headlights off while cranking over the engine to get max power to the starter.
Are you sure you didn't leave the headlight connector unplugged while doing the install. It's next to the fuse box and starter solenoid
