Honda pioneer 520 tires
Headlee
Headlee
7
16
Ontario
Hi Guys
Just wondering what would be the largest tires I can but on my machine without lifting it? The stock tires on this machine are actually pretty good all round but I want some more clearance.
Reactions: JenElio and TxDoc
crewcabrob
crewcabrob
1,029
4,039
Omaha
Hi,
I think Trigger and some others are running 28" tires with spacers added. I know at least one person is running 30", but I don't remember who it is.
Just for your info: I run 27" tires but have a slight rubbing when not going straight.
Lots of good info if you do a quick search.
Rob
Reactions: JenElio and trigger
JenElio
JenElio
73,347
667,338
Loxahatchee, florida
Hi Guys
28's are with arched a arms. 27" is about the max depending on type of tires and true diameter. 26's fit it comfortably unless you start getting crazy wide. 26x11's on 5+2's and 1" spacers made it rub.
🤔 ............I wonder if we can get Richard to paste this Q&A on the home page?
Headlee
Headlee
7
16
Ontario
Thanks for info. Are spacers needed? I want stay as close to 50 as I can.
178,899
This machine is tippy already so adding height and not spreading the stance is ill advised. Adding 1" spacers to all four factory wheels or go with 5+2 offset aftermarkets and you're good.
Reactions: Backwoods
Headlee
Headlee
7
16
Ontario
I think I will go with the 1inch spacers until I burn the stock tires off. Thank you
Derek
Reactions: trigger
