P1000 Honda pioneer snowplow
Parkspremier
Parkspremier
51
171
Central oregon
Working on my snowplow build for my pioneer. Some progress photos 👍🏻
7AD2BC46 5AAF 4341 BF01 16C77842ABAB 8369955A 08FD 4DCE A0E0 31C02451B8DC D0604681 50A2 431D B130 CA1160FE5145 82BB0874 8FD0 4A87 B3CE 2DB379E82CF2 31EB772D A0A7 42AE 9EDA 7A12B7456A13 A39C4651 FAF1 44C7 B0E7 CD203E58E2FA F0FEEBF5 D2B6 41B4 A136 9B61A310D976 0161B123 84C1 4D66 AA39 498FD2B33A4C 5AE8B350 E124 4B71 B07D 5F444867A592
Parkspremier
Parkspremier
51
171
Central oregon
That looks like it will move a lot of snow. It also looks to set further from the rig than others I've seen. Nice job!
Thank you! It’s coming together, it is 84”s wide so when it is angled sharply it will still be wider than my pioneer and I really like the visibility I have from the driver seat 👍🏻
Buggyman
Buggyman
41,833
346,350
ne. ohio
StewB
StewB
711
3,295
It definitely will be receiving a few more gussets before it hits the snow 👍🏻
That will push a lot of snow. It's hard to say how much more diagonal bracing you'll need other than maybe closer to the underbody pins. You have a long, solid chunk of steel giving diagonal strength near the blade under the winch hook. I'm posting photos of my pushbars and cross-bracing, but am really doing that to set up the next part of this post.
I ask this question: is the fairlead to pulley to brush bar mounting a better way to go?
My place is at 8,000 feet in the Wasatch Mountains of Utah. Yep, lots of snow - sometimes 3 feet overnight and a wide, long driveway. I have a KFI Open Trail 66" blade that I've used 6 years on a Teryx4 and now for one year on my Pioneer. Despite all that use, the pushbars and blade are in excellent condition. At about the 5th year of use on the Teryx4, the wire rope had frayed and weakened enough that I cut 4 feet off the end and triple U-bolted the hook back on (with a metal eye). So without a pulley, I lost 4 feet off a 50 foot wireline after 5 years.
I understand the on-winch/wireline stress benefit of a pulley, but will it just wear a longer section of the wire rope as it routes around the fairlead and pulley? Another reason I ask is that the Pioneer underbody mounts seem to be deeper under the machine, which gives a steeper winch angle over the fairlead to the hook attachment behind the blade (third photo). My winch is mounted inverted and the wireline comes out almost direct over the fairlead.
(PS: Ignore the stepladder - I sometimes drop the blade on the stepladder to drain the pushbars which sometimes to collect snow/water).
1642287007260
1642287034181
1642287078961
bumperm
bumperm
1,889
6,743
Gardnerville, NV
Some good, wise and sounds like experienced comments so far. Mine come from far less experience, though I did use a plow on my ATV, I've been using a front mount blower on a cabbed Kubota tractor for 15 years.
I see why you have the added length in your push mount, to accommodate the wider blade. However, that all adds up to a goodly amount of strength needed in the parts, hence the previous suggestions for diagonal bracing I guess. My concern would also be in the amount of lateral force being transmitted to the UTV's frame. With the length of the longer "lever arm", comprised of both the forward half of the angled blade as well as that of the extended mount, that translates into much more twisting force on the mounts than would otherwise be the case with things moved in closer and a narrower blade. This could result in no problems whatsoever as things are all strong enough, things bent and twisted, or lateral forces that overwhelm steering and traction to impede directional control.
Unless you are really sure about the strength of the attach points of the push arm to the frame, You might consider "not" adding a bunch of diagonal bracing right away. Better to have something start to bend out front, than to have to deal with frame damage.
E
elkguide
3,377
7,964
Vermont
My answer to the winch cable wearing by going up and down so much. I went to Tractor Supply and bought a 20' tow strap, cut it in half and just taped it to my winch. (after romoving the hook) After winding about 6 feet in, the tow strap will hold itself in place and works perfect as a plow winch/lift. Here in Vermont with the snow we get and since I end up plowing over a mile of driveways every storm/good overnight wind, I was cutting 5' off my winch cable about twice a year. Since I changed to the tow strap, I haven't had to do any cutting for the past three years.
StewB
StewB
711
3,295
elkguide - I'd previously looked at the tow strap option, which I think would be a perfect seasonal option for the blade.
But I go from my need for a short snow plow lift, to the back country struggles of needing a long winch line. In fact, I had to run the 50' of winch plus a tow strap out to get unstuck two weeks ago.
Parkspremier
Parkspremier
51
171
Central oregon
You bring up a very valid point in having the plow frame being the weak link and not the pioneer frame 👌🏻
Reactions: Lady01 and StewB
Parkspremier
Parkspremier
51
171
Central oregon
This is the video I had found in regards to using the pulley and why I ended up using one. Hope it helps 👍🏻
  • Sad
Parkspremier
Parkspremier
51
171
Central oregon
Amazon.com I don’t personally own this so I can’t say it is effective or not but sounds like a very similar idea to what you did with the tow strap.
Reactions: Lady01 and Buggyman
Parkspremier
Parkspremier
51
171
Central oregon
A question I do have for you guys is, how many bolts do your mounting brackets have that attach it to the frame of the pioneer? I ended up using 1/4” plate and it bolts up using 4 vertically underneath and also using the front 2 bolts horizontally that help hold the the bumper guard and winch mounting bracket. So all in all it utilizes 6 bolts. Hopefully with the bend in the plate to match the under profile of the pioneer and using 6 bolts of various directions this will help limit any potential frame damage that could possible arise 🤞🏻
Reactions: Lady01
StewB
StewB
711
3,295
This video didn't answer the underlying question: does a UTV front plow pulley save or help anything?
Once again, the set up is a winch wireline going forward to a pulley and then back to the machine's brush guard.
Reactions: Lady01
Vikes79
Vikes79
SKOL!
11,534
111,954
South Dakota
  2. Talon X4 LV
YES it is, you cut the load on the cable / rope in 1/2. Your line will last so much longer, it’s a bit slower lift but smoother.
I run a full spool of rope on my winch because I don’t have the plow on always and perhaps need the winch.
not a recent pic but you get the idea.
4E291FCC F516 4134 8010 87805B25B161
Vikes79
Vikes79
SKOL!
11,534
111,954
South Dakota
  2. Talon X4 LV
I also should add that the shock loading is cut in half too.
tjoreo
tjoreo
1,024
1,965
Southern Idaho
I have a synthetic winch line in my rig and after taking the thimble off, I have enough room on my drum for the 50' of line plus the 6' of tow strap like elk guide spoke about. To me its the best of both worlds and in 2 years I haven't broken the tow strap. 1 other advantage I like in the tow strap is it doesn't rats nest like the winch line can sometimes. Plow looks great and even better that you did it yourself.
Sent from my SM-G781V using Tapatalk
