How not to burn your fingers lighting fireworks
  • Thread starter Mark in Northern Iowa
  • Start date
486
2,162
Floyd County, Iowa
kramnella.wixsite.com
That time of the year is coming again, so I thought I would post up my fuse ignitor.
items needed:
- some form of handle, I used a 2' chunk of broom handle
- relay
- push button switch
- "nichrome wire", I think that is what it is called
..... I cut mine from a blower motor resistor out of a junk car
- alligator clips, to hold the "nichrome wire"
- cable and clamps to connect to 12volt battery
On to the pics
11
power plug on handle
power cord to 12 volt
push button on handle, I used a horn button
5
hooked to 12 volt battery, and button pushed
6
the wiring
Wiring
I really should make up a few more.
Every year everybody want to use my ignitor. No burnt fingers.
1) Hook to 12 volt battery
2) Push the button and wait a few seconds
3) When the wire glows red
4) Touch the fuse
5) After the fuse lights, let go of the button
Getting the "nichrome wire" the correct length takes some testing.
- to long, and it will not get hot enough to light the fuse
- to short, and it will burn up your wire if you hold the power button to long
Have a Safe 4th of July, and Have a good day
115,286
Thats like super engineered just to light a firework. Must be an engeneer🤔😂Yes u need to be safe for sure no different when Were shooting our firearms. but you dont have to be in a bomb shelter 😂
but whatever tickles your fancy to feel safe. Sounds like u need to patten that.
