How Winch Brakes have Evolved since the 1970s
TxDoc
TxDoc
1,986
6,711
TEXAS 🇨🇱
photos.app.goo.gl
The GIGGLEPIN GP100 ....$3,800
Twin motor Warn 8274 variant
The 8274, which I still have on a shelf from 1976,...
The 8274 stood for
8-8000 pounds
2- two directions in/out
74-1974, the year first introduced
Introduced in 1974, it replaced the original Belleview winch that was made from 1959-1973. The M8274 has remained basically unchanged since '74, with only minor tweaks including upgraded electrics throughout the years, and a few cosmetic revisions.
They came out with a 50 year anniversary model 8274-50 for about $3,000. 10,000 pounds, now. Year introduced 1998.
In 2008, they had a limited edition of numbered winches, the 8274-60.
In, 2018, they introduced a model 8274-70
The M8274–Warn Industries’ most iconic winch—is evolving. It will maintain all the things buyers love about the product: speed, durability, and its famous shape, but we’ve added more performance and more features. Comes with 150’ of 3/8” diameter lightweight, easy-to-handle Spydura synthetic rope.
Rated Line Pull = 10,000 lbs.
Voltage = 12V
Motor = 6 HP
Remote Control = Remote switch, 12 ft. lead
Gear Ratio = 134.1
Weight = 54.9 lbs.
Synthetic Rope: 150 ft. of 3/8 Spydura rope
Fairlead: = Hawse
Type of Winch = Electric
150' of 3/8" diameter lightweight, easy-to-handle Spydura synthetic rope
High-output 6 HP motor for increased 10,000 lb. pulling capacity (up from 8,000 lbs.)
IP68 waterproof Albright electrical contactor for the ultimate in reliability and control
Restyled high-strength polymer control pack housing for a modern twist on classic styling
Ergonomic stainless steel clutch T-handle is easier to use than before
Two Oilite bushings installed on pinion gear assembly for improved durability in extreme recovery conditions
Bolt-and-washer assembly replaces retaining ring on brake shaft
Made in the USA in Clackamas, Oregon
Sent from my motorola edge plus 2023 using Tapatalk
