P500 Iridium?
Moose308
386
289
Anyone tried iridium spark plugs? Didn't know if they would make a difference.
Reactions: Biteme
bigc
bigc
426
120
iridium plugs will last longer than standard plugs but thats about it they produce the same amount of spark if the heat range is the same
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Im still in the air about these yes supposed to" last longer produce same spark and draw less power" but are also ungapable which is a huge no no in hp building also copper is a better conducter so thats a debate about better spark i still havent found a better plug then the ngk bres for 3$ compaired to 20$
Moose308
386
289
Thanks your my idol.lol
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
I havent changed my plug yet but when i do it will be ngk bre gapped alittle more
Reactions: Biteme
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
No need yet other projects and it was kinda on the bottom of the list
Reactions: Biteme
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Or how come ill gap it alittle more??? If thats the case bigger gap =stronger spark = better burn (more power) but u can only gap to the limitations of your ignition system so its a trial and error in the begining
Reactions: Biteme and Moose308
268,009
How come?
How come? Well son he has a habit of being a bit of a lead food and if he ran out of gas he will need a larger gap for that apple pie moonshine to lite proper. Everyone knows Honda's will run off of dang near everything river water. :p
Reactions: Biteme and jak9922
Irish1
Irish1
35
52
Canada
Trying them as part of a series of changes made to improve cold starting. We will see. At any rate I did want to say that as other have experiences I received my NGK CR6EIA9 without nuts. Many plugs no longer have removable nut so you risk destroying the one you are trying to take it off of. Order them if you chose to go thay way with Iridium or be warned. Cheap not to include them.
Morpheus
Morpheus
109
362
Minnesota
@Irish1 that machine of yours looks really cool. How do you like the tracks?
Irish1
Irish1
35
52
Canada
They are awesome. We get plenty of snow where ai live and there is very little that this machine will not go through. I don't use them in summer have heard it can be hard on the bogies etc...
The gear ratio is quite different though so not real fast. If I were to do it again I would have gone for the 1000 instead of 700 but just for speed as the 700 has plenty o snot for anything.
Thanks
