P700 Keller ball joints size difference
Jfann13338
Jfann13338
27
36
New york
  2. 700-2
Has anyone installed Keller ball joints upper and lower. Today I received my set from SATV. The upper one is clearly way larger than the stock ball joint. I called SATV and they confirmed the P7 abd P1k use the same upper. My concern is it won’t fit in the knuckle. Also any other tips from experience would be helpful. $600 for 4 balls joints I don’t want to mess it up. The machine is at my property 4 hours away so I can’t eveb look.
IMG 0595
115,791
Why not buy another set of stock ones?
They have been strong and last. @Hello_Darkness will fight you in a ring with no boxing gloves and give you the first swing backing them up
  • Haha
Reactions: Coeus and Backwoods
Jfann13338
Jfann13338
27
36
New york
  2. 700-2
Good question. We’re throwing $1000’s at these things and numerous hours of time as well. $250 more than stock what’s the difference. If I was trying to pinch pennies I would have left the damn thing alone and not added 5k worth of other things onto it that’s not really necessary when it comes to functionality. In short what’s the difference. 🧐
115,791
Why yoy putting that much $$ into a P7?
I understand, its your money but it will never be a P1 lol.
JK
Whats the difference? My question is did you search ball joints up top before the purchase? If so you would have got the answer, theres alot of threads on it.
To answer this in short, Not much, just complexity to how they are made is all I found. I had the SATV’s in when I put arms on my P1 and had one broke. Went with OEM’s after that. Been since around 2018 and alot of rough riding were still strong.
I know your a newbie, sorry to sound gruff. It would behoove you to search up top what your gonna purchase before doing so or you will have what you have here.
Jfann13338
Jfann13338
27
36
New york
  2. 700-2
JK
You don’t sound gruff I can take it. So you never installed them ? Cool thanks for the help. I guess I’ll have to be the pioneer of the pioneer 700 to do it. I’ll post pics when the job is done. The 2021 p7 is for a lot of work and a little fun. The 2024 rubicon deluxe is for a little work and more fun and my 2024 outlander 1000 is for crazy s***.
Reactions: Remington
115,791
Gotcha. There are a couple of P7’s out there all beefed up just givin u $hit all good👍🏻
Yes, Ive installed the SATV ball joints but on my P1. They are a tight pressed fit like all ball joints. They were just ok. Nothing special. Deff not worth the $$ IMO
Reactions: Jfann13338
Hello_Darkness
Hello_Darkness
382
1,672
Just to the right of nowhere
Nothin but stock is worth the money
Jfann13338
Jfann13338
27
36
New york
  2. 700-2
I appreciate it brother. I read through one of your past posts on the subject very helpful. You’re the man ! 😎
Similar threads
