Amazon.comExactly where did you get them?
Thank youThere called eagle eye LED 3w
all different colors...they are the
same size hole...as the honda
plastic pins
View attachment 28380 View attachment 28381 View attachment 28382
If ya can't find umExactly where did you get them?
Do they light up enough to see what's beside you?If ya get um & install
ya gotta share pics
I got clear up front & tapped into headlightsThank you
If your hauling ass noDo they light up enough to see what's beside you?
Here's 2 white onesDo they light up enough to see what's beside you?
Here's the back...so if ya put more than oneDo they light up enough to see what's beside you?
I think that will work for what I want it for, want to see if ii'm far enough past trees in the front to make the turn.Here's 2 white ones
during the dayView attachment 28388
Yes that's an RV Porch light in the middleHere's the back...so if ya put more than one
alot more lightView attachment 28389 View attachment 28390
in cab 2 white ones shine lap high perfect
I'm looking for a dash switch set, I don't want to cut in separate switches every time I add something.I think that will work for what I want it for, want to see if ii'm far enough past trees in the front to make the turn.
Is that a BBQ grill mounted to the front? HAHere's the back...so if ya put more than one
PaK of 10.....$13...blackpaint goes bronzeI think that will work for what I want it for, want to see if ii'm far enough past trees in the front to make the turn.
Yeah...I got 4 pak on switchesI'm looking for a dash switch set, I don't want to cut in separate switches every time I add something.
Not mountedIs that a BBQ grill mounted to the front? HA
