P1000 Lowering the P1000
T
TheBreeze
26
114
Van,Tx
Im buying an enclosed stacker trailer to load my P1000 on the lift raise it up and put my jeep 4x4 under it. I know I wont have enough head room without doing something.
You guys who have done mods to get into an enclosed trailer what worked the best without to much hassle? I do not know how much lowering I will need until I get the trailer.
Compress the suspension? Replace the shocks with shorter ones for hauling? Change the tires or just remove them and sit on blocks?
Your thoughts appreciated! I will be on the road all day and will not be able to reply very soon.
Thanks again Eric
Reactions: BWAF
Thanks again Eric
Out of what you listed blocks would be easiest and retain vehicle capabilities
Or chop the cage maybe.
popeye
popeye
3,275
14,644
kapowsin, Wa
6-8 hour worth of fab work on the cage can gain you up to 5" in the rear
Reactions: BWAF
W
WildTurkey
22
39
Nantahala NC
Depending on how much head room you need to gain, don't forget the simple, let the air out of the tires.
Reactions: BWAF
Firemedic530
Firemedic530
387
1,133
West Jefferson, Ohio
I was able to get mine through my 72" door opening. I replaced the shocks with 1/2" steel pipe cut 15" rear and 16" front. It took me and my son 15 minutes to convert each time with a floor jack and 3/8 Milwaukee impact. The bed had to be up because the tires rubbed. I wouldn't do this frequently because I think it weakens the factory nylock nuts.
You will only gain about 2" by removing air from tires and I can't chop the top because I need the bed height for transporting the heaters I sell.
20180224 133613 20180224 133628 20180224 133315 20180224 131828 20180224 131807
Reactions: Plumber32 and BWAF
T
TheBreeze
26
114
Van,Tx
Well got my stacker home today looks like the best way will be remove the cage. I need two feet more head room to get my 4x4 jeep under it.
Thanks for the feedback.
