Max tire Size for a stock Pioneer
MonoJoe
10
16
Calif.
has any one tried the terabytes in 29 X 9 X14 and 29 X 11 X 14 on the Pioneer 1000-5
and if so do they RUB??? and how bad?
Reactions: TripleB and TxDoc
HBarlow
HBarlow
1,626
6,045
Daniels, WV
Judging from the space between my front tires and the body at back of tires 29" would be very close if not touching.
My tires are 28x10x14 with no suspension or other modifications.
115,761
28's are maximum for stock to be sure to not rub. There's About 1,000 threads on this BTW.
On a side note, Haven't seen any pics of your machine from any of your posts. Been on since 19' your sneaky lol
Pics or it didn't happen!
K9Paco
K9Paco
641
2,288
Lake Charles, La
  1. Talon X LV
I had 28x10x14 Terrabites that would rub a little a full lock and compression. But I had a full skid plate that it rubbed on.
HBarlow
HBarlow
1,626
6,045
Daniels, WV
I received a post on my Profile page asking me what size my wheels are. The question should have been posted in the oopen discussion forums so I deleted it but answered it in a PM to the sender.
Here it is in case a new member has the same question.
"The answer to your question is my wheels are a set of four factory original aluminum take-off wheels in standard sizes. Two front are about 6 1/2" wide and rears are about 8" wide. The wheels are standard equipment on Pioneer LE models.""
I purchased them as a set of Pioneer take-offs with oem tires from Shawnee Powersports via their ebay store.
My tires are all four the same size Tensor Regulators in size 28 x 10 x 14.
MonoJoe
10
16
Calif.
Thanks for the info. I am still thinking about the 29 it looks like the room is there except maybe hard compression in tight turn.
More input would be great!!!
Not Great with Photos but I will try!!!
P1013988
HBarlow
HBarlow
1,626
6,045
Daniels, WV
Was it you who posted a few days earlier that you had ordered or purchased a set of four 29" tires?
Is so, I think you'll be in better shape if you return the 29" tires before you mount and use them. Once mounted and driven they are used tires.
I don't think a dozen more posts stating 28" tires are the largest that will not cause interference will change the facts.
  • Haha
