P700 Need new winch
MikeG
MikeG
359
2,478
Baton Rouge LA.
My warn winch failed after 3 uses. I need recommendations on a new replacement winch. Preferably one that is not a warm and can use the same mounting and wiring if possible.
Currently looking at the Badland ZXR 5K and the Viper MD4500-ST
Hillbillytnt
Hillbillytnt
549
2,001
Ky
I’m running the bl5k on a warn mount on a 1000. Not sure about the wiring.
Backwoods
Backwoods
35,100
356,572
Douglasville ga
I don't know about the mounts but I have a viper from the club store its been submerged many times , covered in mud etc. Still works great.
Reactions: trigger
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
the badlands 5k will bokt up and use the same wires as the warn
Sent from my E6910 using Tapatalk
Reactions: Glock21user
U
Ugly
East Tennessee Mudder
386
888
Rocky Top
So your Warn was not covered by any warranty? More info on what happened please
MikeG
MikeG
359
2,478
Baton Rouge LA.
It’s 5 years old. I have only used it three times. Yesterday was the third time, pulled about 25’ of cable out to hook to a tree and when I started winching in it winched about 3’ and let out all the magic smoke from the motor.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Do you know if the motor can be clocked?
eh not really its kinda like the warn xt40 2 bolts going through it oratleasr the one i have is. im on the honda mount and i had to take loose the bottom bolts to be able to swap out.. the motor side will be on same side and thewiresare just right. just had to swap them up to make sure its going right way around.
Reactions: Mudwing
Glock21user
Glock21user
" Nothing succeeds like excess "
1,815
9,039
Livingston county, Mi.
It is when you take the long bolts out of the motor can and rotate it so the terminals are where you want them.
Some can be rotated 90 degrees and some only 180 degrees.
Reactions: MikeG and Mudwing
