P1000 p1000 snow plow kit
Skyking747
Skyking747
53
119
USA
Just curious if any model snow plow kit will work with the p1000-3 with the larger honda oem brush gaurd and a arm gaurds? Here is a pic of my setup. Mainly wanting to make sure I order the right kit for my setup.
Thank you!
IMG 1438 View recent photos
Reactions: Lady01 and HBarlow
Vikes79
Vikes79
SKOL!
11,684
113,345
South Dakota
  2. Talon X4 LV
I’m not a full expert, but I have a Denali snow plow from the club store, and the only modification I had to do was cut a 8” or so piece of the front edge of the trail armor skid plate directly under the winch so that the mount would fit.
I don’t see how the bumper would matter. Arm guards don’t matter, I try to remove mine as I don’t always park my P1k5 in a heated garage. Like mud, they will hold lots of snow which can be hard on the boots etc. this year I forgot to remove them so I have to make sure to clean them off.
Reactions: Buggyman
Skyking747
Skyking747
53
119
USA
The top is irrelevant to the fitment.
Concern would be if you have a warn winch mount with Denali plow as there is a small issue that can be fixed with a grinder.
Check out our Denali plows here SnowPlow's
Discount code SNOW10
Okay good to know. Is there information on what needs to be grinded? I do have a warn winch
JMynes
JMynes
544
3,238
Augusta, Maine
I had one (Bercomac) on a previous SxS (Polaris). It blows snow into the next time zone. Problem is, the rig has the turning radius of an aircraft carrier. Had to go out in the street to get turned around.
Great for a long driveway, but mad overkill for my 100 ft. Using a JD lawn tractor now with all wheel steering. It turns so tight I can almost snowblow behind me.
Skyking747
Skyking747
53
119
USA
Yeah was thinking the same, thank you
Reactions: Buggyman
