Ok there is no air in the system so i will check for mice. Thank you very much for your suggestionsTry and bleed all the air out of the system.
Or you have some mice eating some of your wiring.
This is key. If fan is always on it's the sensor. A temp sensor is nothing more than a potentiometer, or variable resistor, that changes resistance as it's temperature does. Most I've seen and my company uses is the hotter the sensor gets, the less resistance. So a shorted sensor circuit is "hottest". If that's true in this case if you unplug it, the gauge should go to "low" temp on display. First check for bad wires though!If the fan is starting and stopping, and keeping it from overheating, then the sensor would be ok.
But the op says it’s not overheating. My riding buddy is having this same problem, he’s burped it, checked wiring and all good. Waiting for someone to get this figured out lol.Also, just a thought on a non sensor direction... If you have been running in mud, or through soupy puddles, check the radiator for mud packed in the fins. Last year at Takeover, I had to rinse or spray radiator off several times to try to clear packed mud and get air flow through core to avoid overheating.
I'm with you on this, that would be the first thing I would check!Also, just a thought on a non sensor direction... If you have been running in mud, or through soupy puddles, check the radiator for mud packed in the fins. Last year at Takeover, I had to rinse or spray radiator off several times to try to clear packed mud and get air flow through core to avoid overheating.
Thanks- the wires seem to be ok. The fan runs all the time. Can you tell me where the sensor is?This is key. If fan is always on it's the sensor. A temp sensor is nothing more than a potentiometer, or variable resistor, that changes resistance as it's temperature does. Most I've seen and my company uses is the hotter the sensor gets, the less resistance. So a shorted sensor circuit is "hottest". If that's true in this case if you unplug it, the gauge should go to "low" temp on display. First check for bad wires though!
Actually, when you unplug it, it will run all the time (and set a code w/CEL) because the PGM-FI is in limp-in mode.Right in front and a little higher than the spark plug. Unplug that SOB and if the fan stops and gauge goes down - or may possibly throw a code - you know it's the sensor. If it stays the same we'll look at the ECU, or PLC, or whatever Honda calls the "computer".
Right...but suppose the wiring isn't OK? "Appears to be OK" doesn't sound real thorough to me. So why throw a temp sensor at it when it might not fix it? Sometimes they are so cheap it's easy to do...but i'd need more info to do that myself.Right on. I'd still say it's the sensor if that happens because it changed something when you unplugged it. If it was the ECU or wiring that means it's not reading the sensor therefore unplugging it would not change anything.
Absolutely I'm 100% with you. If it was a wiring issue then unplugging the sensor won't change anything. That's what I'm after. I meant "I still say it's the sensor" IF it changes to a code! Not just kills fan and goes to cool. If the wires or ECU is messed up unplugging it will have no change. That's when I said two posts ago if no change then we'll look at ECU (and should have included wires)!Right...but suppose the wiring isn't OK? "Appears to be OK" doesn't sound real thorough to me. So why throw a temp sensor at it when it might not fix it? Sometimes they are so cheap it's easy to do...but i'd need more info to do that myself.
I'm saying that if you unplug one ( healthy machine with no issues or not), it will ALWAYS start the fan and set a code.Unplug that SOB and if the fan stops and gauge goes down - or may possibly throw a code - you know it's the sensor. .
