hey.. i could use some help if yall can.. was pulling on a talon to get it out of some mud then right after i started hearing my p500 making a different noise from the exhaust or so i thought.. down hill from there.. got worse then wouldnt run at all.. i get it home then it ran for about 2-3 min then started making that same noise.. just a change in tone of the engine not a knock or anything like that.. died and no start.. noticed pressure coming back into the airbox and the throttle body pulsating.. shot a little starting fluid in the intake and wouldnt fire off.. later i tried to start it and it would start and run fine then again died and no start.. i noticed that when it would start the throttle body wouldnt pulsate.. i pulled the head and noticed the piston had kissed the intake valve.. almost seems like the timing is moving.. fine one second then off to the point that im losing compression back into the air filter the next.. is this possible? with the shot of starting fluid not working kinda rules out fuel in my mind. seems like the timing wouldnt move back and forth if it jumped. thanks in advance for any assistance.. i did purchase the service manual but its only going to help if i already know whats going on
