Hi guys!
I know there are a few that have removed the rear sway bar on the p1000-5 for slow speed situations. My question is if there is a way to quickly disconnect it.
I'm taking a ride to this place where there is a ton of sand dunes, but also some rock crawling trails. Once we get on the trails we will spend a couple of hours rock crawling. I would like the sway bar connected for the higher speed sand dunes, but would like to quickly disconnect it for the very technical rock crawling sections.
Would it work to just detach one side? or - Would I need to detach both sides and remove it? I'm hoping to just detach it quickly without tire removal for better articulation temporarily.
