P1000 Pioneer 1000-5 water pump
P
P10005stc
Florida
Has anyone heard of an issue with the water pump impeller spinning on the shaft? As in like the impeller is slipping and not spinning the same speed as the shaft? I’m Not sure how the impeller is attached if it’s even possible for it to slip on the shaft? Coolant burped 100 times no air in the system at all, new spal upgraded fan spinning the right direction, Brand new radiator, Brand new thermostat(Tested and it works), Fresh engine ice coolant..Machine gets hot when working under a hard load. But is okay under normal riding conditions
