Pioneer 1000 at Empire Farm Days!
tig
tig
116
176
I'd be surprised if it was there with the on sale date being so far away.
Springer
Springer
312
234
It says they will be at the Michigan State Fair on Sept 4th. Only 30 minute drive so I will try to be there.
Reactions: Hondasxs
scottn57
scottn57
108
294
Buffalo, NY
I think I'm going to take a day and go check it out- if nothing else I'm hoping to test ride a Pioneer 500 on something other than a parking lot.
According to the dealership closest to the event they should definitely have something to test ride...
Reactions: Hondasxs
scottn57
scottn57
108
294
Buffalo, NY
In this news report the Honda rep only mentions the Pioneer 500 and 700-- so probably no dice tomorrow on sighting a P1000 in the wild!
66,816
Let us know.. maybe they will suprize u. Tell them ur from HondaSxS.com. lol.
scottn57
scottn57
108
294
Buffalo, NY
Image Image Image Image
Well, no P1000 to demo ride, but they have a preproduction model on display! Looks solid, very solid. Some of the plastics are rough and pre-production on this example.
Reactions: Hondasxs
scottn57
scottn57
108
294
Buffalo, NY
<Edit- added some notes and comments>
Some notes on what I thought of the P1000 on display:
The build and design seems top notch. The wheel wells seem easily cleanable with few places for mud to accumulate. CV boots seem well protected.
While the seats are not adjustable, they seem well positioned for comfortable riding for most people. The seats are quite comfortable and have almost a gel-foam feel. The center seats was surprisingly comfy with good leg room. The wheel well pushes in on the driver's left foot area but not as severely as the P500. There is a textured foot area higher up to allow the left leg to be stretched out a bit. Should be a fairly comfortable ride with 3 people. This model didn't have the tilt steering wheel / paddle shifters.
Controls and gauges were easily read and reached and the shifters moved and locked in a smooth and solid fashion. The 12v power outlet seemed a bit low and out of the way however. Doors worked well and were solid.
The Honda rep didn't have a key- I suspect they weren't allowed to start it in public to quell any pressure to test ride it. A central NY dealer (who was as anxious as everyone to get behind the wheel of one) was told they should start receiving them late September/early October, and were told they'd get 2/month and would start out with the 5 seater deluxe.
Serviceability seems to be pretty easy and neat from what I could tell- the Honda tech that was present was eager to get ahold of one to take it apart. Apparently he was going to get the chance at some sort of Honda event in the next week or two.
Here are some more photos of the pre-production P1000...
Ac612710d2a350d3d392c8a85fada531
C3394c3cb9a8f6917e27fafc16a6dab6
The left wide of the wheel well is recessed, which isn't great, but necessary to keep things compact. They nicely designed a textured area higher up to allow the left leg to be stretched a bit.
936577566c9e4537c9a48f1c7804092b
You can see the air intake pipe swooping toward the back. Everything looks sealed up well.
Fb519340bd2b5b2603672f3aaed4b9d7
Underhood storage shows the intake (black, left side) with a small storage area above it. It looks like it could hold an extra battery. There's easy access to the wiring behind the dash.
9184c3e60588d1d84daa3c835139fbb9
The air intake is under the hood. The above photo shows the opening with the foam pre-filter removed. The intake swoops down beneath the cabin then back up to the motor. I'm not sure if it had a drain plug on the low spot in case the intake lets in some water- this has been an issue in some Ranger's I ride with- it will be interesting how this air intake works when plowing into some deep water.
E9f89d2e06083ff6b1feab7797f82e29
The underside looks pretty clean re:mud collection and cleanability.
B64a64539394bcbaeb4da25946cdef32
3bcb8de08ad09f85cb922cfd21caa261
Cabd5b1f5591f56304c4b5a969435f07
The oil filter access (internal) looks easy to get to. Right below it is a smaller, similar port labelled DCT- does the transmission have it's own small filter?
B23c028fd028ed248d7928aefbafe58f
9cc8674cec49235c306a7a163cdb0560
The muffler looks decently protected.
0aca66dc8a71a2674170629af9e3339b
Bed lifted- the hydraulic assist works smoothly.
74255a3b668d83478e570a000b36655b
66,816
Wow... Thanks a lot @scottn57.. u the bomb getting these pictures 4 us.
Reactions: LaVell
scottn57
scottn57
108
294
Buffalo, NY
You're welcome- will try to add some comments later tonight- to difficult on the phone... :) Rode the p500 4 times and the P700 twice around the track- too many rules to have enough fun though... ;-)
scottn57
scottn57
108
294
Buffalo, NY
I added more info above....
Looks like there was a lot of thought put into adds.
Looks like spot for a second battery and a winch contactor under the hood.
That would be awesome, much cleaner than the 700.
scottn57
scottn57
108
294
Buffalo, NY
I wish I would have checked out the under hood air intake better after looking at my pictures... Interesting.
sthomp54
sthomp54
375
Thanks for the pics. Do you have any of the dash? Curious about the storage....
scottn57
scottn57
108
294
Buffalo, NY
A couple but they are not great. There is a small center cubby. The glovebox door looked sizable but I didn't think to open it. The one photo shows the center seat leg room.
C5b72f21dcb2751ad2344c0060fe3e2f
A3c4b11626be715124df145e68c2c972
W
WFM
60
30
Maine
Well That's Cool....at least ONE really exists...Thanks for sharing.
271,883
I can see why they don't want this one started, no brake line going into the brake master cylinder reservoir :eek:
Upload 2015 8 14 20 5 54
Thanks for taking the pics and post them along with your impression.
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
Is the engine actually right behind the drivers seat?
Luketheduke
Luketheduke
16
Washington state
Hey scottn57, how tall are you, I'm 6'5", hopefully there's more room in the 1000 cause my knees hit the dash in the 700. That's the only thing holding me back from purchasing the new pioneer 1000. Pics show the dash looking different so I'm hoping!
