Do pioneer 1000s Deluxe and LEs share the same frames and front a arms all years.5 seaters
He said Deluxe vs LE, not SE vs LE.I would think so. The SE is really an LE with some factory options added. (Winch, front poly windshield, roof, small light bar, fender flares, aluminum skid pan and A-arm guards, fancy(er) wheels . . . I think that's about it). The rolling stock is the same, both models share the i4WD.
Can’t imagine the base, Deluxe, LE or SE have different frames.He said Deluxe vs LE, not SE vs LE.
All P1000 frames & A arms 2016 through 2021 are the same from a suspension geometry standpoint. There are some minor changes 2017-2019 model years but nothing that would affect your concerns for what you are asking.Do pioneer 1000s Deluxe and LEs share the same frames and front a arms all years.5 seaters
Agreed. I just didn't understand @bumperm's response in relation to the OP's question.Can’t imagine the base, Deluxe, LE or SE have different frames.
That's 'cause @Bumper had his hea . . . um, mistook the Deluxe for the SE for some inexplicable reason. I think the correct response is, Duh!Agreed. I just didn't understand @bumperm's response in relation to the OP's question.
would a 2016 p1k5 rear frame section fit on a 21 p1k5? i know the rear hitch was beefed up in 18 but i cant see any other changes.All P1000 frames & A arms 2016 through 2021 are the same from a suspension geometry standpoint. There are some minor changes 2017-2019 model years but nothing that would affect your concerns for what you are asking.
It should, but I can't say with 100% certainty.would a 2016 p1k5 rear frame section fit on a 21 p1k5? i know the rear hitch was beefed up in 18 but i cant see any other changes.
