P1000 Pioneer 1000 RotoPax gas can mount
HogHunter
6
15
After a 2 Day long hunting trip on 10,000 Acres with 2 gallons extra fuel and getting back on fumes, I decided to added more fuel. We had the bed loaded with gear so I knew I needed more fuel on board. Here is what I came up with for mounting the rotopax 3 gallon gas can. I added 8th inch thick aluminum diamond plate heat shield to protect the gas from exhaust heat.
20151228 170243 20151228 170309 20151229 101756 20151229 101809
322,690
Looks like that'll work great. Any flex issues
HogHunter
6
15
It's very solid I used metal strips on the back to reinforce the plastic on the other side. My only issue is if I was to drive around with the tailgate down would heat from the Muffler heat the gas in the tank, not that I really use it with the tailgate down but if I wanted to I wonder if it would be an issue. I guess I could build a small heat shield over the existing heat shield to better protect it from heat.
Reactions: CumminsPusher
d_b
d_b
302
240
Very nice job. Good thinking.
G
Glover
Waycross ga
View attachment 8448 View attachment 8449 View attachment 8465 View attachment 8466
Can these mounts be bought?
