P
posterboy
Well We got our first foot of snow in one dump. Well it is still snowing. All I have to say is WOW. This thing plows amazing... Seriously. I have had a Polaris Ranger 500, 800 and 900 and this thing plows way better than those ever could. I also had the Kawasaki Mule Pro FXT before this and I thought that plowed better than the Polaris. I am way impressed.
Now for the not so good. Evan though I am completely amazed by the plowing it could be better. The issue I run into with the Pioneer 1000 is.... I like to plow in Manual mode to keep the constant power and gear. The problem I found out about the Pioneer 1000 is that once you go into reverse and then back into Low it will go back into Automatic mode.... NOT Manual... this was a little disappointing and frustrating. I am hoping there will be a way to override this with a switch somehow... Running it in LOW auto is still good but there are times that it was trying to shift during the time I needed it to push and shift down.I also had the gearing pop out a couple of times from LOW but I think this can be adjusted. And the only other small detail is getting use to the notches on the shifter.
