P1000 Rear shocks.
James-S84
7
12
Minnesota
I have a 2017 1000-5 with 3” lift and 30’s. My rear shocks keep self adjusting so they are maxed out and my tires are tied in. Is there a way to fix this.. thank you in advance.
Reactions: sharp and BWAF
James-S84
7
12
Minnesota
E9B19CCB C90C 4150 9745 8934CC5906D1
You would need to install ned adjustable control arms.
Something like SuperATV, cfab etc.
thank you!
Neohio
Neohio
Beast of the East
14,587
73,812
Painesville Ohio
I am still running the factory arms.
Quite a few members here are running aftermarket arms.
@JTW
@Windrock1000
@Smitty335
Lots and lots more, those are a few right off the top of my head.
Have you done this? Will my axles bind?
That would depend on the lift and if it will work with the SATV arms.
The rear SATV arms move the hub centerline back 1.5” and the fronts move the forward 1.5”, but the add no lift and do not have factory style shock mounts
Some lifts will not work with them if they mount to the lower factory shock mount.
Here’s my rear arms, ignore the angle there’s a 40gallon sprayer in the bed.
D68209f74633534870b7a35cdb835ec2
864f66e8619251b7ec5b9eb2ff5e1436
James-S84
7
12
Minnesota
It is a highlifter 3”... any clue if they are compatible? Satv is what I would like to go with..
Neohio
Neohio
Beast of the East
14,587
73,812
Painesville Ohio
The highlifter kit bolts onto the frame where the upper part of the shock lives.
Some other style lift kits bolted onto the lower mount of the control arm. That is why they are not compatible.
Whether the highlifter works with the Super ATV arms, I do not know.
@JTW? Did you keep the lift on your new arms?
Yup.. but I think mine is 2.5” lift. I just finished running Moab with it and I was pleased with the clearance and suspension
