![NitroxDiver](/data/avatars/m/6/6506.jpg?1499900200)
Yes, If you reset it, it will reset the maintenance tripmeter. You can check this by turning the key and pushing the mode button 5 times.Does anyone know if I can reset the service before the wrench shows up?
Directions to reset Maintenance minder indicator:
To reset the indicator, press and continue to hold the button on the display and turn the ignition switch to "ON". *Do not crank it. The indicator message will light up, and after 2 seconds will flash twice, the maintenance minder is reset.
The maintenance tripmemter and hourmeter will also reset.
...and if I'm not mistaken, this will not display with the engine running? Key on, engine off?Yes, If you reset it, it will reset the maintenance tripmeter. You can check this by turning the key and pushing the mode button 5 times.
You will see miles with a wrench, push it again, you will see hours with the wrench. These will turn to zero when you reset it.
Something like that. But for some reason, I think the trigger is motion....and if I'm not mistaken, this will not display with the engine running? Key on, engine off?
Yep I found you can't see the service indicator when in gear it only displays on my machine in neutral.Something like that. But for some reason, I think the trigger is motion.
I have a Honda 1000-5 that the second service was performed and am trying to reset the maintenance minder indicator. I have followed instructions in the manual but it keeps showing the wrench and switches from 1 to 2 and won’t delet the wrench icon. Any suggestions?For reference.
Hey @Lefty Just want to clearly something for understanding.I have a Honda 1000-5 that the second service was performed and am trying to reset the maintenance minder indicator. I have followed instructions in the manual but it keeps showing the wrench and switches from 1 to 2 and won’t delet the wrench icon. Any suggestions?
