Here's a cheap fix for snow plowing. Why not a rubber plow blade?
Go to a gravel pit and get some used conveyor belt, usually free. Cut the belt to the length of your steel cutter bar. Cut the width to about 12". Remove your steel cutter bar and attach, with 1/2" longer bolts two pieces of your cut conveyor belt. You will need a drill for the bolt holes in the conveyor belt. The belt should be positioned so it is centered on the steel cutter bar. This positioning will give you a very heavy duty rubber cutter that will squeegee your driveway, allow you to push snow out over your lawn without rolling the sod with a steel bar, eliminate wear on the plows skid shoes and make your life easier!. Also, after years of use, you just flip the rubber to get many more years of use. Should you want to do dirt pushing, just remove the rubber conveyor belt, replace the steel blade and go push dirt.
You say this won't work. Nah!! Been using this system on my John Deere Garden tractor plow for the last 23 yrs. Works great for slushy snow as well as 10-12" of the real thing. I have replaced the rubber only once after flipping it. The rubber will not damage your yard, will not tear up your blacktop drive, rides great over uneven cement, brick pavers and gravel / limestone. I have never in 23yrs replaced the skid shoes on the plow as they never touch the ground, but are there if needed, or my steel blade.
For those of you already doing this, your in the club!
Cheers
Cheers
