What should I do with my old P-1005 LE "A-Arms"?
T
thirdparty
68
96
USA
The front left one is bent from hitting a stump, but the rest are just fine. I replaced them with Superatv "A-Arms," but don't really know if the old ones are worth keeping or even trying to sell.
What about the skid protection on the original arms? Is that adaptable to the new arms?
Thanks
Russ989
Russ989
22,642
147,257
Thanks
Most people just save them for someone that ruins one. They really aren’t worth much.
T
thirdparty
68
96
USA
That's kind of what I thought. Maybe there's someone else out there that has an extra P-1005 LE that damaged the right side and has a good left side and we can pair up to donate to someone.
ToddACimer
ToddACimer
Pioneer 1005-2
3,676
15,543
Oshkosh, Wi
I bent 7 stock a-arms before swapping to SuperATV arms. I now have 2000 miles on the SuperATV stuff without any issue. There definitely is a market for used arms. Even if it's just guys running cheap and available parts
Russ989
Russ989
22,642
147,257
Yeah there’s a market but most guys will upgrade before buying stock.
T
thirdparty
68
96
USA
Do you run the steering stops after installing the SuperATV arms? I hate the loss of turning radius. Some people do without problems, but there's all kinds of warnings about adding power when you are at full turn lock.
Any problems there?
ToddACimer
ToddACimer
Pioneer 1005-2
3,676
15,543
Oshkosh, Wi
Any problems there?
I did. Then I ground them to half, now I removed them. At full cramp my tires rub on the springs, back side of the arms and tie rods. I've also chaffed both my front brake lines. I run stock axles and haven't had any issues with them. I rarely use 4x4 and I keep the wheels pretty straight if I do. That's not to say I won't just giver hell to say I didn't get stuck.
My tires are full size 30x10s on 5+2 0 offset wheels.
PXL 20220316 154307416
322,690
Any problems there?
Like Todd I used them at first and then ground in half but wound up pulling because of the turning radius. Had problems with stock axles but had a few before SATV a-arms. Switched out a few different axles and settled in on Rhino 2.0 and haven’t taken out as many.
From what I see if you don’t run lift and forward a-arms you tend to have no more trouble then stock without the limit spacer.
Reactions: pct and Smitty335
